Old 03-02-2004, 07:09 PM
Builder Builder is offline
Question Help Needed: Tank Charging
Hello,
I recently purchased two first generation tanks and was frustrated to find that only one of them would charge. I followed all the directions correctly on how to charge tanks, but when the "CH" appears on the screen the light stays green for the one that won't charge.
Help Please
Old 03-02-2004, 07:51 PM
Combat-Digi-Q's Avatar
Combat-Digi-Q Combat-Digi-Q is offline
Combat Digi Q PRO
Send a message via AIM to Combat-Digi-Q
It might be already charged some, I have found that if the tank has even the slightest bit of charge sometimes the tank will not charge on the tank. I think the controller senses the power left in the tank and tells in to charge it or not. Good luck
Combat Digi Q dedicated
Old 03-02-2004, 07:56 PM
I tried selecting it an ID and running what, if any, was left of the battery life out. It did not respond at all. I am frustrated and very disapointed in these little tanks.
Old 03-03-2004, 08:47 AM
Combat,
You must have been right. I tried to charge this little tank at least 25 different times without success. Out of the blue, it decided it wanted to charge. It may have been because I purposely let it sit on overnight, who knows.
Thanks for your help and good luck with your website.
Old 03-03-2004, 03:32 PM
Combat Digi Q PRO
Good to hear its finally working, and thanks
Old 03-03-2004, 05:57 PM
4-D 4-D is offline
dude ive hade that happen 2 me 2!what ya do is dran it by turning on the tank then take a small moter or LED tuch it 2 the bottem leads A.K.A the mettle spots under the tank and drane it
then try chargeing it or if u wont 2 get getto short out the battery useing one wire right on the + and one on the - some times you can restart real cars like that 2 IM NOT S()!^ING YOU!! ive done it
My car stopped Charging! moxman Bit Char-G / MicroSizers 9 01-13-2007 12:20 AM
Fix for tank with poor performance Alard Combat Digi Q 11 09-12-2003 11:17 AM
Is my tank dead? Halthek Combat Digi Q 3 05-17-2003 04:11 AM
electrical question about charging..resistor values..limiting current.etc Clint Bit Char-G / MicroSizers 17 03-07-2003 03:49 PM
Tank stopped charging Flawed-logic Combat Digi Q 3 02-03-2003 05:40 PM
