Old 03-01-2004, 07:06 PM
2fast4u 2fast4u is offline
Send a message via AIM to 2fast4u
fried electrics and 360 spins?
heres the deal i got new recharge batts and tires and i got a yellow motor without resistor will it fry the electric system? and the tires do not provide traction ne secrets on even good traction?
mini z:ferrari f-40
xmod:body undecided
Old 03-02-2004, 06:45 PM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
put the resistor back on so as not to hurt anything. and ive heard that if you soak the tires in WD-40 that will soften them up. IDK how though. its a lubricant how can it give traction?!
NEVER UNDERESTIMATE THE POWER
Old 03-02-2004, 07:46 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
the things soldered to the motors are NOT resistors, they are capacitors to suppress voltage spikes and feedback noise. it's likely you'll get a slightly reduced range cuz of interference from the motor without the caps suppressing it and possibly damage to the ESC from the feedback noise.
as for traction, try AWD and search around for locking the differentials. also try the tire upgrade kit and use the soft treads. these should help you get some good traction
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 03-03-2004, 02:14 PM
im sorry i mite not have mentioned about what i have i have soft treads and a locked diff i have amasing off the line traction but from there i can do doughnuts with one planted wheel right now im balancing the treads in hopes of better traction balancing means evening them out and making them come in contact with the ground flat and i tried movin the batts... nothin. well my shaq will get awd on thursday so we will s wat happens as for the motor i get reception thru walls and more speed and i removed only the black one also i got the new model ratshaq has been makin improovements
mini z:ferrari f-40
xmod:body undecided
