02-27-2004, 08:47 PM
Any Suggestions
I have a stripped screw stuck in my XMod. Any suggestions on how to remove it? Thanks
02-27-2004, 08:49 PM
boro dori style RC
which screw is it on the car? is the thread stripped or are you talking about the head ([+] thing)?
r34 - rwd
r34 - awd
dd4 - fwd
02-27-2004, 08:52 PM
The head is stripped
02-27-2004, 08:53 PM
And it's in the all wheel drive I was installing
02-27-2004, 08:58 PM
boro dori style RC
you could try using different screwdrivers. try something a little bigger. you can also try flathead screwdrivers. the screwdriver that comes with the xmod is crap.
r34 - rwd
r34 - awd
dd4 - fwd
02-27-2004, 11:47 PM
when turning the screwdriver, push the tip of tha screw driver into tha head of tha screw very strongly with alot of pressure to prevent slipping. like spinit said, try a little bigger screwdriver size also
Custom Customizer- takin xmods to tha limits and hopefully back again for another run
02-28-2004, 12:49 PM
I would use the medium Needle nose pliers. It might take a while but it will work. Or as stated above, a bigger s'driver
02-28-2004, 01:31 PM
anyone know the correct size of these screws i would like to replace them , i have done stripped out a few myself.
02-28-2004, 01:48 PM
If none of the above work, which im pretty sure one will, try this. If you have a dremel tool or something of the sort, grind a slot in the head of the screw to make it a flat head screw. Hope this helps.
02-28-2004, 02:01 PM
2mm dia - 1 point phillips
02-29-2004, 07:40 PM
I'm not a pyro, really.
if you put the regular screwdriver in at an angle but put the pressure down on the screw like in the picture that might work. the green line is the way you have to push down. the angle may be a bit exaggerated.
NEVER UNDERESTIMATE THE POWER
