Old 02-25-2004, 10:27 PM
vtec's Avatar
vtec vtec is offline
not so newbie member
GWS pinion puller
Just wondering which one should I get for use with xmod motors? The GWS pinion puller micro or the standard?? Thanks
Old 02-26-2004, 06:56 PM
SuPrBuGmAn SuPrBuGmAn is offline
Micro
Old 02-27-2004, 05:33 AM
codedat
It doesn't matter they both have the 2mm shaft adaptor. But if you have 1/10 electric scale cars I wouls get the standard. Thats what I use. Besides they are both the same size and the pins are interchangeable.
Old 02-27-2004, 08:10 AM
neurokinetik's Avatar
Mad Scientist
Honestly, I've never seen a 1/10 scale that used a pressed-on pinion. They all normally use pinions held on by setscrews. The only advantage to using the larger puller is that it may be more durable. The disadvantage is that it may not "fit" the 130 motors as well. Mine is a larger type (not the same brand though), and I practically need three hands to use it. (A pair of vise grips and an adjustable wrench serve as substitutes)
Old 02-27-2004, 08:20 AM
WhoMe WhoMe is offline
I got the micro, works great but it is a tight fit between the can and the pinion...so i think a larger one would be harder to squeeze in there.
Old 02-27-2004, 08:43 AM
vtec's Avatar
Thanks for the reponses. All of my 1/10 scale cars use pinions that have set screws so I wouldn't ever need it for that large a motor. So I think I'm just going to order the micro.
Old 02-27-2004, 08:00 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
i bought a hudy pinion puller for 15 bucks shipped (included a buck something for paypal's insurance thingie since i've never shopped at the place before) and it's great. it's very well built
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 03-02-2004, 10:47 PM
TeaQue TeaQue is offline
where did you order from?
--=White Supra=--
S2 9 tooth with Neo Mags
CF driveshaft
AWD
Light Kit
Suspension Kit
AtomicMods.com Lithium Ion upgrade and Sealed Bearings on the way!
found possible pinion Jamezracer XMODS 3 02-02-2004 06:06 PM
pinion puller SupraRacer17 XMODS Parts and Hop-Ups 1 01-06-2004 09:43 PM
Pinion Puller SupraRacer17 XMODS Parts and Hop-Ups 1 01-04-2004 12:03 AM
Will this pinion puller work? geofroley XMODS Mods and Projects 7 12-29-2003 05:28 PM
pinion puller rob2fastx XMODS 4 12-18-2003 05:41 AM
