Old 02-23-2004, 09:09 PM
350z-zz 350z-zz is offline
Best mods to improve handling
hey guys im sorta new to xmods but im learning quick thanks to these types of forums and stuff
Anyway, i have a skyline xmod with a SB s2 hybrid w/ upgraded 100uf capacitor. With this i am able to keep up with my other mini rc (overland/mini-z) however the handling and turning radius are where you can really see the difference between my cars. I am aware and was aware that the turning radius is an issue with the xmods but every so often i hear people with ways to tweak it. I was wondering what are the best upgrade parts to help this issue as well as home made mods that could help. I am also considering doing a 5 cell upgrade however as i hear this would hinder the steering even more due the increase of power/speed.
Old 02-23-2004, 09:21 PM
RC 2NR RC 2NR is offline
TinyRC XModder
There is a mod where you replace a couple of resitors which will decrease the turning radius. I don't have a link though.
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
Old 02-23-2004, 09:38 PM
cyrc's Avatar
cyrc cyrc is offline
i love lab rATS ther rad.
4.5 tie rod and awd its back in stores now and 5 cell wont hurt handling if you put these on it will be better still
death is the number one killer in america ...dont become a statistic.
Old 02-24-2004, 12:45 AM
spinitsidewayz!'s Avatar
spinitsidewayz! spinitsidewayz! is offline
boro dori style RC
some really cheap homemade mods could be tefloning the tie rod and supergluing the tires. i dont think they would improve turning radius but they improve handling. the suspension on these xmods is too loose. it suXKKksss
r34 - rwd
r34 - awd
dd4 - fwd
Old 02-24-2004, 06:00 PM
Tdevil Tdevil is offline
I have found a significant improvement in turning radius by taking the diff apart, using some type of diff lube on it and getting it to spin more freely.
As the diff spins more freely it is easier for the inside tire to stop spinning while the outside tire spins making the car corner sharper.
Learned racing the bigger scales that a smooth diff made all the difference.
Old 02-26-2004, 07:07 PM
xmodsman's Avatar
xmodsman xmodsman is offline
Send a message via AIM to xmodsman
i gotta question if i made the yellow thing(or red upgrade)longer would that make the radious wider or less wider?
blue RSX
wild silver body kit
stage 2 drift motor
5th cell mod
soft springs front
hard back
3.5 steering
custom plastic skidplate
white rims
metal lugnuts
mini-z tires
and custom painted chasis
Old 02-26-2004, 08:46 PM
TinyRC XModder
All that does is increase toe-in, which makes turning more responsive.
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
Old 02-26-2004, 09:34 PM
xmodsman's Avatar
so shortening it would make it turn in a smaller radious?
blue RSX
stage 2 drift motor
5th cell mod
soft springs front
hard back
3.5 steering
white rims
metal lugnuts
mini-z tires
Old 02-27-2004, 12:08 AM
boro dori style RC
stock(yellow) Neutral 0 degree toe in
1.5 toe in
3 toe in
4.5 toe in
i think the stock rod would give you the smallest turning radius since toe in causes the car to go in a straight line.
alignment info page
http://www.ozebiz.com.au/racetech/theory/align.html
from all the sources ive read, they all state the opposite. toe-in would give you stability and would resist turning. i dont know where you get your info?
r34 - rwd
r34 - awd
dd4 - fwd
Old 02-27-2004, 07:59 AM
TinyRC XModder
Sorry, I guess your right.
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
Most Cost Effective Mods rggtm XMODS Parts and Hop-Ups 20 07-01-2004 01:12 AM
My Xmod mods livingplasma XMODS Mods and Projects 1 12-10-2003 01:49 PM
mods on epoch Reeyad Epoch RC1/43 Parts and Hop-Ups 0 03-17-2003 06:04 AM
step by step how to for mods Twistid ZipZaps 2 12-27-2002 04:03 PM
Anyone Found any "Do It Yourself" Mods for ZipZaps? hawks10 Bit Char-G / MicroSizers 6 09-25-2002 12:41 PM
