Go Back   TinyRC.com > Tips, Mods and Reviews
Old 02-20-2004, 05:32 PM
Racer9's Avatar
Racer9 Racer9 is offline
Tiny RC Pro
Radio Shack 1:32 R/C car
Overall Rating: Very Good
Quality: 10 (No problems yet! Knock on wood)
Overall Design: 9 (Very Strong design and also stable. Has two quirks mentioned later)
Speed: 9 (Good but slower than stock Auldey)
Handling: 10 (VERY good! Stable car that is almost impossible to spin)
Tires: 10 ( Same design as Auldey stock tires but much softer)
Wheels: 10 (The best wheels ever! enough said)
The cars I have are from RS and are the best deal ever! The have the softest tires I have ever seen. They have enough grip to hold on extremely well even on dusty surfaces (like a dirty hardwood floor for example) so the dirt isn't a prob. The cars are even sealed well. When I took it apart there is three screws to hold on the body. The motor pod has 4 screws to hold the top on. The motor endbell partially sticks out of the end too. It could use a rubber gasket around the motor to seal anything out but otherwise good. It also has a lexan shield that will cover it from dirt from the top but not the bottom. I am sure there is ways of shielding the bottom. The body top has a gold or copper plated antenna glued in. It has a wire running down to the PCB. The actual antenna looks like this:
IIIIIII
IIIIIII
It performs well but...
It will probably help to do the relay mod due to being fairly slow but otherwise very good cars! I would reccomend one very much! Especially for $15 at RS.
can you return xmods to radio shack timshotrod XMODS 1 01-22-2004 04:59 PM
Bit Char-G: FAQs (Updated: Jan 6th, '03) Namuna Bit Char-G / MicroSizers 15 08-14-2003 11:04 PM
radio shack workers!!! mattsx2005 ZipZaps 10 04-22-2003 07:31 PM
Newbie: Which R/C car should I get? st5150 Bit Char-G / MicroSizers 7 09-01-2002 01:31 AM
Newbie: Which R/C car should I get? st5150 Miscellaneous Discussion 1 09-01-2002 01:04 AM
