02-20-2004, 06:57 AM
track questions
just wondering what is the smallest track i could build indoors that will still have some fun to it?
i was thinking maybe 8 X 6 or 8 X 10? lmk what you think ,feel free to post pics of your tracks also. thanks
02-20-2004, 03:31 PM
Hippygeek
This is my Track. It's a Wide L track but is only setup as a Wide Oval for now. It's 13' X 9' and we have a blast with it.
Xmods are cool, but Mini Z's rock
02-20-2004, 03:34 PM
pretty cool , what about a 2ft lane by 10 ft long oval track ? would it be raceable w/ 2 stock xmods?
02-20-2004, 06:31 PM
Hippygeek
Depends on your driving skill.
The corners would be very tight.
You would probably need the 4.5 tie rod to negotiate them.
02-21-2004, 01:17 AM
boro dori style RC
the 4.5 rod would give you worse cornering. u'd need toe-out if you wanted tighter cornering. but then itd be very twitchy.
r34 - rwd
r34 - awd
dd4 - fwd
02-21-2004, 08:47 PM
boro dori style RC
in real cars toe in gives you stability and toe out gives you more cornering. maybe it doesnt apply to xmods, but from my experience toe in gave me understeer. ::shrug::
r34 - rwd
r34 - awd
dd4 - fwd
02-21-2004, 09:07 PM
like my dog??
excuse my ignorence, but what are the laser pointers for??
--Chris
Aka...aero528
02-22-2004, 10:18 AM
Hippygeek
It's a Lap Counter, connected to a Computer.
02-22-2004, 10:26 AM
like my dog??
ok, but how do they work that far off the ground?
--Chris
Aka...aero528
02-22-2004, 10:38 AM
TinyRC XModder
In real cars it's the opposite. Toe-out is for stability, toe-in is for more responsiveness.
What software are you using?
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
02-22-2004, 11:16 AM
Hippygeek
You put a flag on the antenna. It breaks the beam as it goes by.
Here are pics of the actual working model, and of the flags I use.
02-22-2004, 11:39 AM
Hippygeek
Here is a pic of the board that is inside the pipe with the holes. It has 6 phototransistors on it but only 4 are in use. The original wiring diagram I got was for 6 cars but did not work correctly so I found another wiring diagram for a 4 car setup and it works fine.
02-22-2004, 11:50 AM
Hippygeek
It's called Virtual Race System. I got it here.
http://www.i4style.co.uk/vrs/
02-22-2004, 05:17 PM
boro dori style RC
if you read any automotive 101 book, its toe in for stability and toe out for more response. why would you want toe out for more cornering? because your inside wheel travels in a smaller circle then the outside wheel. toe in gives you understeer.
http://www.z31.com/alignment.shtml
http://www.yokohamatire.com/utmeasures.asp
r34 - rwd
r34 - awd
dd4 - fwd
