Old 02-19-2004, 10:38 AM
shane-o shane-o is offline
Send a message via AIM to shane-o Send a message via Yahoo to shane-o
water dipping?
what is all this I've read about "water dipping" your motors? Ive read about people doing that... but what exactly does it do?
Quick!!! look ahead! see that!?!?! ITS MY DUST!!! BWWWAHHHH AAAAAH HAAAAAA
Old 02-19-2004, 12:25 PM
SuPrBuGmAn SuPrBuGmAn is offline
Basically... It just breaks them in faster.
Old 02-19-2004, 05:54 PM
Martlet21 Martlet21 is offline
Send a message via AIM to Martlet21
Water dipping cleaned my motors out and lets you use a better lubricant, like Slick 50. With this better lube, the motor accellerates faster and has a higher top speed.
My Tiny R/C:
XMODS Yellow Skyline GT-R
AWD
Jumbo Tires
Stock everything else
Old 02-20-2004, 01:54 PM
I know i must seem like an idiot... but do I just dip the motor in water?
Old 02-20-2004, 02:24 PM
You put the motor in clean water, and run it until the batteries die. Then you spray electric motor oil in every crevice and orifice on the can you can find and run the motor again until its dried out.
Old 02-20-2004, 03:15 PM
QPizzle QPizzle is offline
Send a message via AIM to QPizzle
excuse me but, putting a motor in water, while its running, isnt that an eletricity hazard? or does the motor actually run in the water, if so, what would i do with my wires, should they be above the water or in it?
Xmods Skyline:
Champagne Gold paintjob
Mild bodykit w/wild spoiler
CL lights
CF centershaft
locked diff.
2nd stg. drift setup
hard slick rear/soft slick front
hard sus. rear/med sus. front
6 Cell w/IC-3's
FET upgrade
Dremel polished motor heatsink (mass mirror)
Flat black rims/chassis/front and rear plates
only thing i really needed.. and only thing i didnt buy:
AWD kit (out of stock everywhere...)
Old 02-20-2004, 03:31 PM
Dangle the power source above water and have the wires from the power source with the motor connected submerged in the water.
Its not a electrical hazard.
The motor will run in the water, under more load than it would in the air, the extra work to get the brushes moving against the comm breaks the brushes and comms in faster than they would at 1bar. The water will turn grey/milky from the parts breaking in by the time the batteries start running dry. Remove it from the water, dry it as best as you can, fill the can with electric motor oil, throw some new batteries in the power source and start running the motor again.
There is an entire thread on this here http://pub238.ezboard.com/fxmodrcfrm...picID=47.topic
Old 02-20-2004, 03:57 PM
thanks
water dipped Sb? kasper01001 XMODS 38 08-01-2006 12:01 PM
Water Tires? bvsciguy ZipZaps SE 14 09-16-2003 07:43 PM
Dipping motor in water? Smurf Bit Char-G / MicroSizers 28 06-22-2003 02:50 AM
custom chassis production has started ronak26 Bit Char-G / MicroSizers 45 02-24-2003 03:18 AM
my bit fell on water! henry Bit Char-G / MicroSizers 9 12-02-2002 09:52 PM
