Go Back   TinyRC.com > 1/24 and Smaller > Auldey / Radi-Can > Auldey (All)
Old 02-17-2004, 03:19 PM
Racer9's Avatar
Racer9 Racer9 is offline
Tiny RC Pro
RS Clone
I got a Radio Shack clone. It is 1:32 scale and is a Ford Focus RS WRC rally car. It handles well but its slower than a stock Auldey. Anyone else have one?
Old 02-20-2004, 04:03 PM
Racer9's Avatar
Tiny RC Pro
Overall Rating: Very Good
Quality: 10 (No problems yet! Knock on wood)
Overall Design: 9 (Very Strong design and also stable. Has two quirks mentioned later)
Speed: 9 (Good but slower than stock Auldey)
Handling: 10 (VERY good! Stable car that is almost impossible to spin)
Tires: 10 ( Same design as Auldey stock tires but much softer)
Wheels: 10 (The best wheels ever! enough said)
The cars I have are from RS and are the best deal ever! The have the softest tires I have ever seen. They have enough grip to hold on extremely well even on dusty surfaces (like a dirty hardwood floor for example) so the dirt isn't a prob. The cars are even sealed well. When I took it apart there is three screws to hold on the body. The motor pod has 4 screws to hold the top on. The motor endbell partially sticks out of the end too. It could use a rubber gasket around the motor to seal anything out but otherwise good. It also has a lexan shield that will cover it from dirt from the top but not the bottom. I am sure there is ways of shielding the bottom. The body top has a gold or copper plated antenna glued in. It has a wire running down to the PCB. The actual antenna looks like this:
IIIIIII
IIIIIII
It performs well but...
It will probably help to do the relay mod due to being fairly slow but otherwise very good cars! I would reccomend one very much! Especially for $15 at RS.
Old 02-20-2004, 04:35 PM
Racer9's Avatar
Tiny RC Pro
Here it is:
Old 02-24-2004, 01:02 AM
mde mde is offline
post pics of the motor and electronics
Post pictures of the running gear and measurements of the motor please.
I may be able to source motors for you.
Old 02-24-2004, 02:01 PM
Racer9's Avatar
Tiny RC Pro
It uses regular Auldey Motors and the drive train is very similar just it has the gears on the left (when viewed from behind)
Old 02-24-2004, 11:05 PM
mde mde is offline
Does it also use the same magnetic steering set up as the race tin?
Old 02-25-2004, 02:45 PM
Racer9's Avatar
Tiny RC Pro
Nope motorized by an open can motor exactly like in the Epochs drive setup. It seems to not reach all the way unless you steer from the complete oppiste steering lock!
Old 02-25-2004, 07:36 PM
mde mde is offline
Interesting I' ll have to check the local RS to see if they have one.
Old 04-05-2004, 05:36 PM
george george is offline
happy drifting
i saw them. how fast?
black xmod civic.
black supra wing.
hood scoop.
black skyline wheels.
other mods.
Old 04-20-2004, 01:42 PM
Racer9's Avatar
Tiny RC Pro
Slower than a stock Auldey but handles much better.
Old 04-20-2004, 06:35 PM
happy drifting
i dont have an auldey so could you give me a ball park
black xmod civic.
black supra wing.
hood scoop.
other mods.
Clone Reviews! Kenkudaki Bit Char-G / MicroSizers 32 03-06-2006 03:53 PM
motorwroks / other clone fused together! Impreza WR reX Bit Char-G Mods and Projects 0 02-21-2003 11:57 PM
clone ctlr works on ZZ but ZZ cntlr doesn't work on clone? ejaf ZipZaps 2 12-11-2002 03:05 PM
More Clone BS BillyBonz Bit Char-G / MicroSizers 2 08-30-2002 02:28 PM
Tomy vs. Clone BillyBonz Bit Char-G / MicroSizers 2 08-26-2002 03:54 PM
