Go Back   TinyRC.com > 1/24 and Smaller > XMODS > XMODS Science
Old 02-15-2004, 02:11 PM
RC 2NR RC 2NR is offline
TinyRC XModder
Fully adjustable plate-type LSD tutorial
EDIT: Requires all wheel drive
Well, the other day I had the idea to make an LSD that used plates (like many drift cars do). The advantage of this is that it's adjustable by tightening the three screws. I used the AWD ball differential, but I guess you could use one of the gear diffs with a little modification. This mod (if done with the ball diff), is fully reversable, if you don't like it.
The "plates" I used are three metal washers, you can see them in the pic below, here are the specifications:
-Width: 3/8"
-Thickness: 1/32"
-The interior diameter isn't very important, but it's 3/16"
I took out the middle peice of the diff, as well as the five ball bearings.
One of the most important steps is to use some good lubricant between all the plates. Otherwise it will be too tight, and will basicaly be a locked dif. I used this lubricant.
These are all the peices I used:
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
Old 02-15-2004, 02:16 PM
TinyRC XModder
The great thing about this is that it's adjustable from as free as the ball diff, to locked.
You must turn all three screws the same amount.
As you can see from the pic all you have to do is take one wheel off to adjust it.
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
Old 02-15-2004, 06:36 PM
Silent_NightR34's Avatar
Got Mini-z?
i like the idea...maybe you could put a piece of paper in between each one to act as a fricton disk...where did you get the washers from?
Old 02-15-2004, 07:59 PM
TinyRC XModder
The washers have enough friction in between them, especially because you can increase the friction by tightening the screws.
The washers are just some that happend to be lying around, I was lucky that they were the exact width and thickness I needed.
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
Old 02-15-2004, 11:08 PM
suprafreak33 suprafreak33 is offline
got supra?
cool idea
xmod
blue supra
6 cell
all upgrades[by rs]
Old 02-16-2004, 10:41 AM
NissanGTR01 NissanGTR01 is offline
Send a message via AIM to NissanGTR01 Send a message via Yahoo to NissanGTR01
thats a good idea but what i did with mine is i left the balls in and just took the little mounts that the screws go into and shaved them down a bit and you get the same effect but if you want fwd then all you do is pull the one tire off and loosen them up and voila fwd or you can go almos as tight as locked it all depends on how much you shave down the little mounts
Nissan Racing
KA24E
7500 RPM
280 HP
270FT-lbs
Old 02-16-2004, 09:17 PM
neurokinetik's Avatar
Mad Scientist
This is a good mod.
Old 02-16-2004, 09:29 PM
TinyRC XModder
Originally posted by neurokinetik
This is a good mod.
Coming from you that says a lot. Thanks.
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
Old 02-16-2004, 09:51 PM
TinyRC XModder
I meant to upload this earlier, here is the diff installed.
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
Old 02-18-2004, 09:23 PM
spinitsidewayz!'s Avatar
spinitsidewayz! spinitsidewayz! is offline
boro dori style RC
not to kill the idea or anything but if you loosen the lsd enough wouldnt it slip and lose power instead of sending it to the wheels? i am running tamiya washers that are 1/4th inch in my stock gear diff with all the gears in. its fully adjustable. b4 when i ran it w/o the gears and the plates inverted the thing just slips
r34 - rwd
r34 - awd
dd4 - fwd
Old 02-18-2004, 09:48 PM
boro dori style RC
heres the set up im running now. ive been messing with gear diffs for a while. ive never worked with a ball diff so i wouldnt know how it would work but thats a nice diff you have there all we need now is a fully adjustable suspension
r34 - rwd
r34 - awd
dd4 - fwd
Old 02-18-2004, 10:11 PM
TinyRC XModder
Well, the reason I even have the ball differential is because I have the AWD kit . When I loosen the diff. more power goes to the front wheels, reducing oversteer, and increasing understeer. When I tighten the diff. there is less slip between the back two wheels, which increases oversteer, and decreases understeer.
When tightening or loosening the diff. a very small amout will drasticaly change how the car handles. It takes a lot of experimenting to get the desiered amount of slip.
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
Old 02-18-2004, 10:27 PM
boro dori style RC
yeah it does take alot of adjusting to get that desired setting. hmm i c now how you set it up. kind of like a front biased all wheel drive. so ur rear diff is also doubling as a center differential sort of in a way as it adjusts power distribution between the front and rear. nice. i didnt think of that lol. im running rwd. GO 2WD GO!!
r34 - rwd
r34 - awd
dd4 - fwd
Old 02-18-2004, 10:41 PM
TinyRC XModder
Yeah, just not that versitile. You aren't actualy giving the rear more torque, it oversteers more because the rear wheels are locked or almost locked, which is why it oversteers.
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
Old 02-18-2004, 10:55 PM
boro dori style RC
so what are ur suspension/tire/diff settings right now and on what kinda surface?
r34 - rwd
r34 - awd
dd4 - fwd
Adjustable, Gear-type LSD for Gen 1 Xmods color0 XMODS Mods and Projects 0 03-06-2006 01:53 AM
Fully Adjustable Front Suspension Steve ZipZaps 6 11-16-2002 10:57 PM
