Old 10-10-2002, 08:33 PM
lnx_author's Avatar
lnx_author lnx_author is offline
Join the GNU Generation!
Zip Zap dbl charge?
dunno if this has been covered before, but i just noticed something today when fooling around my w/new zz (Porsche - stock, unmodded)...
1. place on charger
2. charge
3. run - runtime a couple minutes
4. place on charger
5. charge
6. remove from charger
7. wait a sec...
8. charge again
9. run - runtime about doubled!?!?!!!!
has anyone noticed that you can double-charge the zz for more runtime?
sorry if this is common knowledge...
Old 10-10-2002, 08:37 PM
Spitfire7001 Spitfire7001 is offline
ive notcied it a bit
My ZipZap Mod Site
www.sal.wronger.com/mods.html
Old 10-10-2002, 09:11 PM
amsTaTic
I did the same thing today. Since yesterday, when I got my ZZs, I was just charging once, then running them. They ran for about two minutes before needing recharging.
Today, I charged two consecutive times without running the car, and now my run time has more than doubled to about four and a half minutes per charge...
Old 10-10-2002, 10:12 PM
Shacky Shacky is offline
Yup, I've been doing that from day 1, since I knew it worked well with the Bit Char-G. The 150 mAH rated one takes 3-4 charges.
Also, I wonder if you can use the QFM capacitor mod on a ZZ to give it double the charge automatically?
Old 10-10-2002, 10:19 PM
JediYoda56 JediYoda56 is offline
Send a message via Yahoo to JediYoda56
Shacky if I am understanding you correctly your bit batt can actually be charged 3 or 4 times at a time? How long is that runtime?
Old 10-10-2002, 10:38 PM
Eh, no. Not mine. I do charge 3 times sometimes, but I haven't timed how long it lasts. The 3-4 charges are for the 150 mAH battery found in the parts and mods on this site.
Old 10-10-2002, 10:40 PM
Oh I knew about that thought you meant the reguler batt's, my mistake. Personally I get around 4 min run time on one charge anyway.
Old 10-10-2002, 10:46 PM
go_zz_go's Avatar
go_zz_go go_zz_go is offline
more power!!
shesh i get about 10 minutes of straight hard driving normally i go fifeteen minutes or so on a stock zz
Old 10-10-2002, 11:02 PM
catman25 catman25 is offline
my red light wont go on.. i charge it and i try againbut the charge lit wont light up ..
Old 10-11-2002, 12:25 AM
amsTaTic
I don't know if you tried this, but I noticed that I had to wait a few seconds, (sometimes up to 10-15 seconds), between the chargings. If I try it too soon, the LED stays green...
Old 10-11-2002, 10:10 AM
lowerdfool's Avatar
lowerdfool lowerdfool is offline
Microrcfool
Send a message via AIM to lowerdfool Send a message via Yahoo to lowerdfool
if you've messed around with the battery any the terminals have moved around and aren't making contact with your charging base anymore. look at the bottom of the car and the charging terminals should be filling the entire rear holes in the chassis. mine slid forward just a bit and I couldn't figure out why it wouldn't charge till I looked at the bottom.
"What's a low fool?" lol
Old 10-11-2002, 10:23 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
mine did the same thing. i had to remove the circuit board and push the terminal back into place but it still does that somewhat.
oh well my battery lasts at least 10 minutes even with the 21.5 motor.
Old 10-19-2002, 10:40 PM
joeNuggetz joeNuggetz is offline
So, should this work with a dual batter mod in series? My controller wont even turn RED if I attach a dual modded car. I dont think its even passing current unless the light is red. Dont know for sure. I will check.
Old 10-20-2002, 02:44 AM
Steve's Avatar
Steve Steve is offline
zipped up tight!
The controller has a voltage regulator of sorts that prevents you from charging past 1.5volts, even with a three cell radio, so charging a dual cell car that requires 3volts just won't happen. There is a mod out there to bypass the regulator, but then you have to guess at how long to charge for.
Zip Zap SE FAQ Bad Company Tips, Mods and Reviews 4 11-16-2006 09:21 AM
My Zip Zap GuiltyEnder ZipZaps 1 04-11-2004 10:38 PM
Microsizer and Zip Zap lot intermision For Sale/Trade 1 12-22-2003 12:19 PM
My Evil Zip Zaps a pain to charge Racemonster505 ZipZaps 4 10-24-2002 10:23 PM
