02-06-2004, 11:44 AM
Low Voltage Warning Light
I found a schematic for a low voltage warning light system. Two LEDs come on when the voltage drops below a given amount. This is good because the car wouldn't suddenly stop when the voltage dropped. In stead you could finish a lap or drive to the "pits" or what have you. It should be fairly simple to modify this circuit to a cut off if that's what you want. Check it out
http://homepages.paradise.net.nz/bhabbott/lvw.html
Rez
a7i20ci7y
Seven Cities RC
02-06-2004, 12:28 PM
TinyRC XModder
Looks interesting..I'd like to see how this works out for someone.
BTW, Rez your sig is hillarious.
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
02-06-2004, 12:32 PM
Hmm...., well that a lots simpler than what i had in mind, i was going to use the a/d of a PIC and monitor the voltage, then shut down within a certain range, if i have time i'll try to mock up the circuit on a proto board
02-06-2004, 12:42 PM
That would be awesome. I'm no electrical engineer, so I have no idea if this guy's rig will even work
Glad someone got the joke, 2NR
Rez
a7i20ci7y
Seven Cities RC
