Old 02-04-2004, 09:49 PM
FrozenKamikaze's Avatar
FrozenKamikaze FrozenKamikaze is offline
Don't point at Me!
Is the HeatSink really needed?
I just got a Supra and I already had the Stage2 motor upgrade to use on My Civic so the Q is is the HeatSink really needed on the Stage2 motors because obviousely one of 'em is going to have to make it without one.
Black Honda Civic coup
Rechargable batt upgrade.
Command Logic light kit.
Stage2 Drift.
Tire upgrade.
Steering & Suspension upgrade.
1.5 steering rod.
Yellow springs all the way around.
Soon to come: Body kit
Old 02-04-2004, 10:46 PM
jaubery jaubery is offline
It depends on the driving conditions. If your running on carpet or a high friction surface you need a heatsink. Some people on the forum have made their own custom heat sinks.
Old 02-04-2004, 10:49 PM
Don't point at Me!
I run on pretty smooth cement to blacktop outdoors.
Stage2 Drift.
Tire upgrade.
1.5 steering rod.
Old 02-05-2004, 12:31 PM
theMonster's Avatar
Got Brains?
it's a MUST if you're running more than 4 cells and a stage-2 or better also.
This is your brain.....
Old 02-05-2004, 04:47 PM
SuPrBuGmAn SuPrBuGmAn is offline
The RS S2 heatsink is just about worthless. Heatsinks are great for motors when you are running a hotter setup or a a high friction surface, but you'll want to use something better than the RS one...
Steal one off some RAM and cut it to fit.
Old 02-05-2004, 04:52 PM
aero528's Avatar
aero528 aero528 is offline
like my dog??
Send a message via AIM to aero528
Have you touched a just run s-2 motor latley?? Nah, j/k but they do get hot and they do lose performence if you dont have one.
--Chris
Aka...aero528
Old 02-05-2004, 06:41 PM
Don't point at Me!
Well any suggestions? I don't have two.....
Stage2 Drift.
Tire upgrade.
1.5 steering rod.
Old 02-05-2004, 06:46 PM
Make one.
Old 02-05-2004, 08:08 PM
Savior*insider Savior*insider is offline
just think about this, during production they had to stop halfway thru and cut the board in half and add the heatsink dude to overheating. id say its necessary.
I am the insider, i kno all
current xmod stats: everything. i got the hook up =P
Old 02-05-2004, 10:55 PM
Don't point at Me!
Any idea how to ghetto rig something to substitute?
Stage2 Drift.
Tire upgrade.
1.5 steering rod.
Old 02-06-2004, 01:44 AM
d00kie's Avatar
d00kie d00kie is offline
It's super useless!
The heatsink fits in tight which should mean more contact.
Anyway, I doubt that you can mount the heatsink without damaging/removing the sticker. I just took a blade and carved a line at the number ratings so I can still identifythe motor.
I also noticed a slight warm feel on the heatsink after a minute or two of solid running. However, the bottom of the chassis had warm air coming out of the little vents.
Looks like the heatsink does help dissipate heat but there is barely any airflow in the body. However, the heat from the stage 2 motors isn't that hot.
Old 02-06-2004, 10:12 PM
After 15 minutes or so running on rcp-track my stage 2 is hot enough to burn your fingers.
Old 02-06-2004, 11:09 PM
spitty12's Avatar
spitty12 spitty12 is offline
Happiness is a warm gun..
Send a message via AIM to spitty12
Leave the heat sink on, I use thermal compound for computer heat sinks to promote maximum heat disapation.
Tin-Foil HeatSink mod. FrozenKamikaze XMODS 34 01-04-2004 08:42 AM
stage 2 cooling without heatsink Lucid Dreams XMODS 4 12-17-2003 10:56 AM
Need info on a heatsink viperkilla XMODS 2 12-05-2003 10:37 PM
is heatsink needed? skklown XMODS 14 12-05-2003 07:51 PM
Heatsink viperkilla XMODS 5 11-16-2003 05:32 PM
