Old 02-01-2004, 04:55 PM
kasper01001's Avatar
kasper01001 kasper01001 is offline
("\(0.o)/") Rawr!
Send a message via AIM to kasper01001
o crap i'm screwed...
ok so i was adding a skid plate to my civic project I was taking out one of the screw until i noticed that I was turning it the wrong way! so now its just stuck there and i can't take it out any suggest on how to?
Xmod Parts Help
Old 02-01-2004, 05:23 PM
cyrc's Avatar
cyrc cyrc is offline
i love lab rATS ther rad.
yeah get a drill with a small bit and then drill through the srew and pinch it and pull it it works on larger item i havent had to do it on my x mod yet though but i strip screws too some times hope this helps
death is the number one killer in america ...dont become a statistic.
Old 02-01-2004, 07:57 PM
pacificwarriors's Avatar
pacificwarriors pacificwarriors is offline
MY ENZO!!!!!!
dumb moment
Old 02-01-2004, 10:16 PM
("\(0.o)/") Rawr!
Originally posted by pacificwarriors
dumb moment
yup.....
o yea the screw is not stripped its more.....over tightend and it moves freely counter and cloockwise its just i can't get the darn thing out
Xmod Parts Help
Old 02-01-2004, 10:32 PM
Delorean Freak Delorean Freak is offline
Send a message via AIM to Delorean Freak Send a message via Yahoo to Delorean Freak
...Pretty much meaning it's stripped... :-P
Old 02-01-2004, 10:45 PM
("\(0.o)/") Rawr!
o sorry i though the meaning of stripped was when the screw driver tip can't grip the cross on the screw or over did it making it impossible to take out with a normal screw driver? o well i guess it has more definitions lol
Xmod Parts Help
Old 02-02-2004, 04:00 PM
KnotHole's Avatar
KnotHole KnotHole is offline
JesUSAves
Lightbulb ...This might work.
Sorry to hear about your problem with the screw but it's not as big a deal as you might think. There are a couple of things that you can do.
1- You can take a needle and stick it under the screw head and then put pressure on it in a upwards kind of way while unscrewing it.
2-You can also get some glue that wont stick forever and glue your screwdriver tip to the screw and lift up while unscrewing it.
ie...modeling glue might work good.
Both of those ways should work if done the right way. Either way, just make sure that you take your time with it. After you get it out your going to find that you will still have a larger hole than the screw that came out.
I have read that some people have used a small drop of superglue in the hole to make the screw threads tight again. They say to put in a drop and then put the screw back in. Let it dry for a bit and then unscrew it and put another drop in the hole and screw it back down and let it dry again.
I think it might just work out fine for you. Just remember "DO NOT" use a bunch of glue. Just small drops.
Let us know if this works out for you & may God Bless.
KnotHole...
Awd Is Crap ! ! ! ! ! Mr BigShot XMODS Mods and Projects 12 12-24-2003 10:18 PM
are the drr hop ups crap? catman25 Dynamite Rocket Racer 0 03-10-2003 09:01 PM
Cripple Crap cisco Bit Char-G / MicroSizers 7 12-07-2002 06:23 PM
what does a crip crap look like CARFREAK Bit Char-G Mods and Projects 1 11-06-2002 05:27 PM
Subaru Crip Crap CARFREAK Bit Char-G Mods and Projects 3 11-06-2002 08:25 AM
