Old 01-30-2004, 04:08 PM
civic freak's Avatar
civic freak civic freak is offline
Tiny RC Guru
Snow tires?
recently weve had quite a lot of snow here and while im out of school i get bored can any body help me make a snow/ice tire
Old 01-30-2004, 06:05 PM
itsme
Don't be worried on tires, be worried about the electronics...
Old 01-30-2004, 06:07 PM
Ireland Ireland is offline
I remember two years ago my robotics team used something called "file cards" on the robot to make it grip the carpet. I am pretty sure that the real use of these "file cards" is to clean a thingy (i forget wtf its called. it's like sandpaper for metal) anyways, if you can get a hold of some file cards then i would guess that you could just cut them to size and then double sticky tape them around the tire (or wheel, i guess, but the ridge might cause a problem. If you have foam tire upgrade then maybe try it on that wheel) then just kinda snip the spikes on the file cards so they are short enough to fit under the body and not hit the chassis (front wheels) or the batteries (back wheels) These would, in theory, be mini snow tires.
If you don't have or don't have access to file cards, then something that might work (this is in theory, just like the above) would be taking a flash card or some other type of fairly rigid peice of paper and poking a bunch of pins through it (the kind with the small and flat head) This would make like a mock file card. Then just do the same as above for trimming and installing.
Also, if ur gonna run your xmod in the snow, I guarantee you're gonna get snow in your xmod. I've done this before when there was like 1/8th of an inch of snow on my driveway and when I came in there was so much snow on it that I used a blow dryer to get it all off. You might want to make up a way to try to stop this.
Old 01-30-2004, 06:40 PM
Tiny RC Guru
thanx guys but i was thinking more along the lines of spikes,dont worry about the electronics its ice im running them on and ive done it before well not really just more like a bunch of doughnuts
Old 01-30-2004, 09:08 PM
newbitowner's Avatar
newbitowner newbitowner is offline
maybe you can make the tires sticky by rolling them in coke and letting it dry before use...just an idea
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
Old 01-30-2004, 09:19 PM
I Shall Return!
hmm, you could put thumb tacts in the tires (spikes out) and trim the spikes to clear the chassis (lol this would be a mean thing to do on someones foot lol)
Old 01-31-2004, 01:46 PM
pacificwarriors's Avatar
pacificwarriors pacificwarriors is offline
MY ENZO!!!!!!
how about some really small chain
Old 01-31-2004, 02:52 PM
spitty12's Avatar
spitty12 spitty12 is offline
Happiness is a warm gun..
Send a message via AIM to spitty12
Good idea ireland, try the hardware store for a file card, I think he is refering to the thing that people use to clean out metal files. Don't use dry coke, it will be a mess and not help at all.
Old 01-31-2004, 06:33 PM
um, what I said above was an idea for spikes on your tires lol. mayb u shud read it again or sumthin
Old 02-04-2004, 09:35 PM
bob256
A low grit sandpaper might work, cut into strips, or razor blades from a shaving razor( be careful though ) wrapped around the tires.
Old 02-05-2004, 08:57 PM
MY ENZO!!!!!!
the razor blade idea is a really good idea i would have never have thought of that
Day's goodies and Cheap Foam Tires Jazz32 XMODS Parts and Hop-Ups 5 07-20-2006 11:01 AM
lego tires, xmod rims Marius666 XMODS Mods and Projects 19 04-13-2006 08:53 AM
best tires xxspeednplayaxx XMODS Mods and Projects 8 01-04-2004 06:24 AM
