Old 01-28-2004, 04:21 PM
ppcheee's Avatar
ppcheee ppcheee is offline
sseiko sks195- mine :)
Angry argh!
has anyone else had the problem of things getting unsoldered reeeally easy? my battery holders both need to be resoldered, even though i was pret carefull with them. its really annoying..
Old 01-28-2004, 04:37 PM
theMonster's Avatar
Got Brains?
hmmmmm
The solder joints I made between the cut battery wire and the battery holder have NEVER broke. The ones that the manufacturer did on the car HAVE ALL BROKE. Just goes to show that 10 year olds kids in Taiwan can't solder worth spit.
This is your brain.....
Old 01-28-2004, 06:28 PM
ppcheee's Avatar
i wonde rif my shop teacher might letme stay afta skoo to use their soldering irons... or do they make low heat solder and irons?
Old 01-28-2004, 07:38 PM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
RS has 20/40 watt ones for about $22 theres a switch for 20 or 40 watt
NEVER UNDERESTIMATE THE POWER
Old 01-28-2004, 09:46 PM
RC 2NR RC 2NR is offline
TinyRC XModder
I've lost count on how many solder joints have broken, I'd say about 15.
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
Old 01-28-2004, 11:55 PM
kasper01001's Avatar
kasper01001 kasper01001 is offline
("\(0.o)/") Rawr!
Send a message via AIM to kasper01001
Re: hmmmmm
I resoldered everything after one of the batt wires came out, and now i do the same to the new xmods i get....
LMAO!!!
Xmod Parts Help
Old 01-29-2004, 05:19 AM
ppcheee's Avatar
thanks aperson. does anyone here know the difference betwen the pen type irons and the gun ones besides the shape?
Old 01-29-2004, 07:40 AM
TinyRC XModder
The gun ones have a trigger...you press the trigger to heat it up. The guns take less time to heat up. A gun cost more too. The pen irons are sufficent for me (I've got a 25 watt).
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
Old 01-30-2004, 10:29 PM
jaubery jaubery is offline
I must be lucky. I have 3 xmods and so far I have only soldered one ant. wire and two motor capacitors back on. I have had them since early December and they are used hard!
Old 02-08-2004, 02:53 PM
ppcheee's Avatar
i just got a soldering gun and re-soldered everything
Old 02-08-2004, 03:46 PM
neurokinetik's Avatar
Mad Scientist
I carry my solder station with me every race night, and there hasn't been a single night that we haven't needed to use it at least once...
Old 02-10-2004, 04:58 PM
moose moose is offline
i have broken two solder joints for the batts. No biggy it was a 5 min fix.
Skyline stage2 drift lights
Old 02-10-2004, 05:16 PM
KennyD KennyD is offline
Send a message via ICQ to KennyD Send a message via AIM to KennyD
I've heard alot about solder stations. What all do the consist of? Whats the price range on one and where can you get one?
Thanks!
Old 02-10-2004, 05:21 PM
scatmanjohn01 scatmanjohn01 is offline
actually, i notices that multi stranded wire tends to come unsoldered faster then single strand, since single strand is kinda springie ya know?
Old 02-11-2004, 07:18 PM
aperson's Avatar
but single strand breaks easier if you move it too much. that stuff is used usually in house wiring.
Cross Frequencies!! ARGH!!! Need Help! syncronized Bit Char-G / MicroSizers 0 05-24-2003 08:25 PM
Australian Site Hacked kmvargo Bit Char-G / MicroSizers 14 12-27-2002 01:41 AM
