Old 01-24-2004, 08:45 AM
maxximum attack
Keep the dust out (rally guys)
Find it here:
http://bitpimps.lixlink.com/pages/ph...?p=36218#36218
Old 01-24-2004, 09:53 AM
Joey's Avatar
Joey Joey is offline
Good addition to the skidplate.
Mazda Savanna RX-7
stage 2 motor | spaced wheels
Old 01-24-2004, 01:41 PM
maxximum attack
I tried to do a rear one just now, but it needed too much trimming and it lost functionality so ill keep the front only.
Old 01-24-2004, 03:33 PM
pigeonfarmboy's Avatar
pigeonfarmboy pigeonfarmboy is offline
Go Banana!
cool man. i'd love to see a lift kit as well. Rallying would be a neat thing with these.
Old 01-25-2004, 08:08 AM
maxximum attack
I am going out right now and try to run it off-road (RWD) and see how it goes. I might attach the read mudflap to the body instead of the chassis.
Old 01-25-2004, 08:01 PM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
this is awesome. when i get at least one of my cars going again, ill need to make me some of these. ill probably integrate them into my new skid plate though.
NEVER UNDERESTIMATE THE POWER
Old 01-25-2004, 11:48 PM
eetoi's Avatar
eetoi eetoi is offline
Hardcore Otaku
aww man, I thought you meant keep the dust out of the gears! I am getting a lot of dust even in the tennis courts! I can only imagine how much more on dirt... Maybe I'll attempt to seal up the drivetrain myself... and longer susp. arms and a lift kit as well
Old 01-26-2004, 10:26 AM
pacificwarriors's Avatar
pacificwarriors pacificwarriors is offline
MY ENZO!!!!!!
i figured out how to do a lift kit but it is really hard to explain. when my dremel starts working again i will try it
Old 01-26-2004, 12:39 PM
eetoi's Avatar
Hardcore Otaku
Yay! Hard to explain? Could you at least try?
Old 01-26-2004, 01:05 PM
MY ENZO!!!!!!
ok i will do my best
first you have 2 dremel out a section of plasitc under the u joint. Then you have to take the suspension out, after that you fill the place where the bottom of the suspension is held in. After that has dried drill a small hole directly under the a-arm mount, then place the suspenion in normally. This makes the a-arm higher than usual causing a lift in the rear, formally known as a lift kit. Iam sorry nothing for the front yet. That wasnt as hard as i thought it would be
Old 01-26-2004, 01:12 PM
eetoi's Avatar
Hardcore Otaku
O.O That's it? I get it
Old 01-26-2004, 05:36 PM
MY ENZO!!!!!!
Thats it, for the rear. However i have no idea about how 2 do the front. I thought it would be much harder 2 explain
Old 01-26-2004, 07:22 PM
maxximum attack
Did you do It yet?
Does it actually work?
How much more rideheight did you get?
Can you post a pic if you did?
This (if it works) would realllllll big to me and all other rally guys
Old 01-26-2004, 09:10 PM
MY ENZO!!!!!!
Originally posted by maxximum attack
Did you do It yet?
sorry but no dremel yet. but i would say it would be about a 1 inch lift. next time i go to my friends house maybe we can use his dads dremel
Old 01-26-2004, 10:51 PM
newbitowner's Avatar
newbitowner newbitowner is offline
You guys should also add this simple mod...
See the shield?
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
Akura2/diets or other experienced TTT guys micro-rc-guy TTTT 2 01-13-2006 03:32 PM
Rally Tracks!!! FullyBaked Tracks 3 01-03-2006 06:06 PM
Rally car gallery crazydave Bit Char-G Gallery 34 06-07-2003 09:58 PM
Rally Mod ~Bit+Racer+3~ Bit Char-G Mods and Projects 3 01-22-2003 07:25 AM
