Old 01-23-2004, 02:36 PM
turboMan turboMan is offline
Question custom springs
If I cut a stiff and a loose in half and the stuck them on the same damper would it make a difference? And how do you lower car beside body kits??
If birds fly south for the winter why is there bird poop on my car in the winter
Old 01-24-2004, 07:55 AM
I Shall Return!
if you did that, then youd make whats called a dual rate spring, so youd have the best of both world, soft springyness for turns, but hard for traction... in my opinion i prefer stiffness,
i made super stiff springs simply and easily, i put 2 hard spirng in each dampener in the rear, and 2 stock springs in the front dampeners. i then stretched both setups to about 3cm in length, and stuck them in my car (please not that they are very hard to get in being so stiff and wanting to expand) one problem i came apon was that by doin this i disaligned the rear wheels, so i used a twistie (wraped in electrical tape to look beter) from the jewel fruit section to limit the springs movement (ironicly made for an even stiffer setup) the twisties (both f and r) act as stabilizer bars, limiting the movement of both wheels together (super traction) but allowing indiviual movement per wheel... heres some pics. "sorry for the mess i just got up (7:00 am and was 2 lazy to make my bed)
I Shall Return!
front w/o tape
Old 01-24-2004, 09:21 AM
Bad Company's Avatar
Here is a link to a thread where I did the same thing you want to do...
http://www.tinyrc.com/forums/showthr...l+rate+springs
custom srings civic freak XMODS Mods and Projects 18 01-04-2004 07:37 PM
Custom Springs 'fo Sale ph2t For Sale/Trade 18 09-25-2003 02:26 AM
Custom Springs ph2t Bit Char-G / MicroSizers 0 05-04-2003 07:40 PM
Custom springs for microsizers Silent_NightR34 Bit Char-G Mods and Projects 2 12-25-2002 05:55 PM
question about springs 8ate8 Bit Char-G / MicroSizers 1 12-05-2002 11:32 PM
