Old 01-19-2004, 07:48 PM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
Stacking Mosfets
ive been thinking about using the mosfets from my old electronics and stack them on my new ones. i was wondering if it matters which way they are. like do they have to be on the exact same places or it doesnt matter. Thanks in advance.
NEVER UNDERESTIMATE THE POWER
Old 01-19-2004, 08:08 PM
R33E8 R33E8 is offline
I heard it does matter which way they go on. Are the mosfets your adding on from another xmod or somthing totally diffrent?
Xmods Civic:
Custom 36t 28gauge ball bearing neo mag motor, Soft treaded tires, 5 spoke rims, AWD, Hard springs in the back soft in the front, lowered BC's way, 6 cell with I-C3s, and one awsome drifter/driver/racer.
Old 01-20-2004, 08:12 AM
aperson's Avatar
they're from my fried electronics. one of them is questionable of the way its on because when i tried to take one off with a torch and air compressor. i went to put it back on after it cooled and the torch litterally burned a hole in the electronics.
Old 01-20-2004, 10:01 AM
neurokinetik's Avatar
Mad Scientist
If you tried to take it off with a torch, don't expect it to ever work again...
I think I'm going to have to make a tutorial on FET removal.
Old 01-20-2004, 10:02 AM
SuPrBuGmAn SuPrBuGmAn is offline
A torch is not a viable option to replace a soldering iron.
Old 01-20-2004, 11:27 AM
aperson's Avatar
well that was before i got my new soldering iron. also before this...
Old 01-21-2004, 08:12 AM
aperson's Avatar
i figured out how to safely remove them and did some practicing last night. heat up one side of the mosfet and stick a skinny screwdriver or hobby knife. then just take some needle nose pliers and heat up the other side and take it off. i found that they dont want to stay in place when you're soldering them on. could i superglue them together or should i use another kind of glue?
Old 01-21-2004, 09:14 AM
Mad Scientist
You were on the right track on that removal method, but if you want to do it the best way, get some of that super-fine wire wrapping wire from RS, strip it, and pass it underneath the pins of the side you are desoldering. If you do it gently, the pins will not get bent up, and the chip can easily be reinstalled.
Old 01-21-2004, 02:41 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
or go to RS and copper braid to get rid of the solder....just be careful you're not removing solder from thigns aorund it lol
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 01-21-2004, 04:57 PM
Mad Scientist
The desoldering braid that RS sells is garbage. I will only use Chem-wick by Chemtronics. It doesn't fray and fall apart while you are using it like the RS stuff does. But yes, using desoldering braid before doing the wire trick is how I remove surface mount chips of all sizes.
Old 01-21-2004, 05:39 PM
TypeZer0's Avatar
0reZepyT
really? it doesn't seem so bad when i use it. it stays together for me at least.
Old 01-21-2004, 07:33 PM
procyonlator
clue me in
whats a mosfet?
Old 01-22-2004, 08:16 AM
aperson's Avatar
the 4 black chips on the PCB board. ther are 8 pins coming out of each one.
you mean bending the pins that are still soldered on right?
Old 01-22-2004, 07:16 PM
97PrizmLsi 97PrizmLsi is offline
That solder wick is amazing
Old 01-23-2004, 08:15 AM
aperson's Avatar
there are 4 so i think that there are 2 Forward & 2 Reverse. when its in low only 1 each way is working and then its in High both are working each way. i think i may have to make this external. there are going to be some serious fitting problems getting the PCB back in.
A place to buy mosfets megamighty ZipZaps Mods and Projects 0 10-07-2006 01:31 PM
Mosfets problem eltacocr ZipZaps 0 05-06-2004 06:05 PM
stacking Mosfets aperson XMODS 0 12-16-2003 11:54 AM
what are mosfets? suprafan420 ZipZaps 5 10-07-2003 04:28 PM
Buying Mosfets red2cwm Bit Char-G / MicroSizers 11 08-04-2003 01:14 AM
