01-18-2004, 11:39 PM
Best for cheap
I have the RSX with a stage 2 drift (fastest motor I have seen for the races I do because the rest have horrible accelerations for what I have tried.)on it and metal bearings and stiff suspension all around. I am new to this, and I ordered a 5th cell to put on and today I am buying the IC3's for my car. Now I want to have a fast car and not have to do much technically. I have heard things about mightymods.com superstar ssr motor is good. CF driveshaft people said is good. I mostly do shorter races about the length of a basketball court. My friends are running the same setup as I have but I want to be faster. I want to fly off the line and have a high top speed too. What are the recommendations and links to buy these parts at. I don't want to spend more than $50 on everything. Thanks for all the input in advance. Also I own the AWD upgrade kit if somebody suggests I put that on.
01-19-2004, 07:24 AM
TinyRC XModder
First, put the AWD kit on, they don't slow your car down like some people say.
As for a motor theres a few things you could do: put Crest Spinbrush magnets in it, try this thread. Or you could just get one of these. Also a good motor can be found on Ebay if you search for the seller: speedologist.
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
01-19-2004, 09:25 AM
The link to the motor online it doesn't have a pinion gear on it? I want a fully assembled motor not one where I have to work on it. I will work on car just not motor. Thanks
01-19-2004, 12:22 PM
Anybody please? What engine does neurokinetik' civic have that is in the videos. I want that baby! or something equivilant to that.
01-19-2004, 05:22 PM
ANYBODY!
01-19-2004, 05:34 PM
neurokinetik works on his car, seems as if you wouldn't want to have to do that.
Once you've gone through the RS Xmod mods, there aren't too many drop-in applications ready just yet. There is the CF driveshaft, CF chasis(soon), CF braces(I think you can get them on ebay), and you may want to try a stock MiniZ motor(beware of the faster MiniZ motors or you may have to actually do some work on your car  ).
01-19-2004, 06:39 PM
Mad Scientist
That's a hand-wound 180 motor. Not compatible with an RSX, unfortunately, it just won't fit.
01-19-2004, 07:41 PM
I also have a supra I could put the motor in. If you wind me a motor like yours that will make my car go as fast, then I will buy it off you for $30
01-19-2004, 07:42 PM
The reason I don't want to mess with the engine myself is becasue I am afraid of breaking something. I can install I just don't want to ruin my xmod.
01-19-2004, 08:27 PM
Engines are cheap. You can buy Mabuchi 130 motors for less than $3 at RadioShack, Hobby Shops, or other electronics places. Get a few and practice. Once you are confident that you can wind the motor and solder the wires to the comms, get a 180 and do the same to it - its fairly hard to mod a 180 motor to the point of where its too hot and burns MOSFETs. Its much easier to burn your FETs with the 130.
01-20-2004, 01:51 PM
Where can I buy the fastest 180?
