aight....short tutorial
1. u need a zz se and u need the command logic lights for the xmod.
2. pull the headlights off the light pcb from the zz se and strip the wires about half way.
3. since the zz se lights are small and have small leads, cut the headlights off the command logic set about 2 inches from the tip of the light.
4. separate the strands and strip the wire about an inch.
5. now the kind of tricky part.....turn on ur xmod with the command logic plugged in....make sure the controller is on 2 so the lights come on.....u need to match up the leads so the positives and negatives are lined up.
6. twist the leads together and electric tape them together. do the same for each light.
7. test the lights and then ur oFF!!!!
a better tutorial would be badcompanies...except instead of using 2 command logic kits use one kit and a set of zipzap se lights heres the link to bad companies if he doesn't mind....
http://www.tinyrc.com/forums/showthr...threadid=14427
