Go Back   TinyRC.com > 1/24 and Smaller > XMODS > XMODS Science
Old 01-16-2004, 12:46 PM
Exaran's Avatar
Exaran Exaran is offline
Send a message via AIM to Exaran
Talking HowTo-SB magnet mod: No pinion removal !!!
Needed:
One Xmods motor to be modified
One spinbrush motor
Small screwdrivers
Tweezers
Maybe a soldering iron
My motor tech vocabulary is poor, so bear with me...
1-Get your 2 motors
Do steps 2-6 to each motor
2-Pry the tabs on the motors up that hold the endcaps on
3-Insert a screwdriver in the tiny gap between the end cap and the little plastic piece inbetween the connectors, and pry. This allows you to remove the end cap while leaving the wires and brushes in place
4-Pivot the brushes out of the motor being careful not to bend or twist them too much (you may need to pop off one of the solder points on the can)
5-Use the tweezers and pull out the "U" clip on the top of the motor that holds the magnets in place.
6-Use the tweezers to pull the magnets from the can. Set them aside so you know what side of which motor they came from.
Steps 7- do only to the Xmods motor
7-Put the SB magnets into the Xmods can. Put the LEFT SB magnet into the LEFT side of the Xmods can and vice versa. In other words the same sides they came from (Or else your motor will run backwards, like mine did at first ) [EDIT: I have corrected this step]
8-Put the "U" clip back into the motor. Push it totally into the can, but so that there is a little of the clip left right in front of the magnets for you to grab in case you need to change magnets again.
9-piviot the brushes back into the motor, carefully, again.
10-pop the endcap back on, and bend the little tabs back down to hold the cap in place
11-Try spinning the pinion, it should turn freely. You will feel a small "grabbing" force as you turn from the stronger magnets.
12-Solder the connection back to the can, if you had to break it in step 4. Remember to rough up the can a little with sandpaper or a file to make the solder stick better.
13-dispose of the extra spinbrush parts or save for experimentation
14-install the motor in the car, insert fresh batteries, and play!
Sliver Xmods Skyline
SB hybrid S1 drift motor - Yay doughnuts!
Old 01-16-2004, 08:01 PM
RC 2NR RC 2NR is offline
TinyRC XModder
Thanks...this is a good idea, because when I tried to take the pinion of my drag motor with the flame method, I destroyed it.
I tried it and it works great.
Any moderator: I think this should go into XMods>XMod Science
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
Old 01-17-2004, 09:35 AM
Bad Company's Avatar
I will move this over for now pending further test results from this mod.
Exaran: Where in Richmond are you? There are a couple members here looking to get together for weekly racing/modding.
Old 01-17-2004, 10:09 AM
TinyRC XModder
I would recommend putting a little general purpose oil in the can and running it with a battery for a few minutes until most of the oil comes out. This makes it run faster and cooler.
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
Old 01-17-2004, 02:33 PM
Exaran's Avatar
Glad you like my idea
I'm in east richmond, near the airport. That would be awesome to get together and race. I've spent about 20 hours modding and 1 hour driving cause I have nowhere to drive in my house
I sent you an email with my contact info
Old 01-17-2004, 04:15 PM
Nathan's Avatar
Nathan Nathan is offline
Bad Driver
Wow. Never thought of that. Good work- I don't think there is a pinion puller within 200 miles of the Alamo . This will save me much time.
Old 01-17-2004, 07:25 PM
TinyRC XModder
I haven't heard of anybody being able to get one of the pinions off without breaking their pinion puller.
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
Old 01-18-2004, 04:34 PM
nobodyhere962's Avatar
nobodyhere962 nobodyhere962 is offline
Honda 4 life
Send a message via AIM to nobodyhere962
does it matter wat brand the spinbrush is(crest)
and how do u get the motor out
sry im a bit dense and new at this
"Why do they have locks on the doors for stores that are open 24-7?"
that counts holidays too!
A new Question every year i think!
Old 01-18-2004, 08:23 PM
TinyRC XModder
Yes, it has to be a Crest Spinbrush.
To get the motor out:
1. Pull the battery cover off
2. Take off or cut off the rubber gasket
3. Pull the toothbrush apart
4. Remove the 4 screws that hold the motor in
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
Old 01-19-2004, 02:26 PM
Honda 4 life
thanx
Old 01-20-2004, 10:05 AM
neurokinetik's Avatar
Mad Scientist
My puller is still functional even after several pinion removals. I have to flatten the thin metal plate by putting it into a vise when I'm done, along with using Vise-Grips to hold it in place when I'm using it, but it does hold up, for the most part.
Old 01-20-2004, 11:32 AM
SuPrBuGmAn SuPrBuGmAn is offline
I ordered one last night, supposedly it holds up quite nicely. Do a search on GWS Pinion Puller for several online stores that carry them.
Old 01-20-2004, 11:59 AM
sinistar sinistar is offline
Um I'm a bit frustrated....
I have done this successfuly but sometimes I have had trouble getting the solder to stick to the can. I tried sandpaper, my taper file, even a small hole pattern. And Have not been able to get the solder to stick. Is there something one of you know that I don't? Does it matter if the can gets hot before puting the solder on the can or do you just put the solder on like you would just anything? I really have been wondering about this because I have a puller but I'm in a fix as just as to how to get the solder to stay on the can. Right now I'm just taking some narrow RS electrical tape and banding the lose solder connections to the can. But this really is bothersome with pending heatsink developments and other motor related engin-e-rings. Please somebody tell me what might be going on.
question #6 is now ready out of the
toaster and has popped up for you.
Old 01-20-2004, 01:00 PM
Mad Scientist
Re: Um I'm a bit frustrated....
It takes a good soldering iron, and a little patience. I just heat the can where I want the cap soldered, and put a blob of solder there. I then tin the lead of the cap. Then I heat the blob up, and put the tinned wire into it while it is melted. Let it cool, and you are sorted.
Old 01-20-2004, 09:02 PM
IBAUCLAPla IBAUCLAPla is offline
HELPP!!!!!!!!! I get up to the part where you remove the Uclip. I don't see a Uclip anywhere. I did steps 1-4 perfect on my Xmod stagge one motor. I cant get the magnets out. Please help
Pinion Removal SupraFreak00 XMODS Parts and Hop-Ups 1 06-09-2004 01:18 PM
Pinion Removal ? webpilot XMODS Mods and Projects 13 12-04-2003 07:48 PM
Magnet source for improved steering mod DesertJedi Bit Char-G Parts and Hop-Ups 1 10-29-2002 05:19 PM
