Old 01-16-2004, 12:29 AM
Exaran's Avatar
Exaran Exaran is offline
Send a message via AIM to Exaran
Used SB magnets...going backwards?
I took the magnets from a SpinBrush motor and put them into my spare stage 1 drift motor. To me, the power and speed is incredible (dont have enough room to get to speed normally), but there's one problem....When I pull the trigger on the controller It goes in reverse!!!
Did I put the magnets in backwards? Or do the different magnets reverse the polarity of the motor?
Should I try repositioning the magnets, or do i just need to swap the wires to the motor? If i need to rewire, can I just swap the pins in the connector, or will i need to move the capacitors/resistors/etc.?
Thanks for the help
Sliver Xmods Skyline
SB hybrid S1 drift motor - Yay doughnuts!
Old 01-16-2004, 07:50 AM
RC 2NR RC 2NR is offline
TinyRC XModder
You have to put the leads on the "wrong" way, because XMods run backward compared to most RCs.
Old 01-16-2004, 07:54 AM
neurokinetik's Avatar
Mad Scientist
Take your pick. Flip the magnets to the opposite sides of the motor, or else reverse the wires. Whichever is easier for you.
Motor Efficiency Mod LBRC Epoch RC1/43 Parts and Hop-Ups 0 01-26-2005 02:42 AM
Spinbrush magnets (courtesy of xmod forums) cdog4w Mini-X Parts and Hop-Ups 2 02-28-2004 10:34 AM
Magnets hostyle XMODS Parts and Hop-Ups 5 02-03-2004 08:11 PM
Sterring magnets bwsk8 Bit Char-G / MicroSizers 6 03-31-2003 04:54 AM
Neodymium magnets? bluemax_1 Mini-X 1 03-29-2003 12:36 AM
