Old 01-13-2004, 12:21 AM
miller miller is offline
She only tries to turn left.
Pretty much the car always wants to go left. The servo seems in a perpetual state of going left and dosent want to go right ever. When I take apart the servo the little servo motor always spins one way once the remote is turned on and when I try to turn left with the remote the servo motor stops. I checked the crystal, installed fresh batteries and checked all the solder points on the esc and stuff like that. I did resolder a thicker gauge wire on where the receiver wire is that goes to the antenna. So now their is the stock wire and a thicker wire there. Would that mess things up? Any clues as to what causes my car to turn only one way?
Old 01-13-2004, 12:50 PM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
if it did it before you installed the thicker wire take it back. there might be a way to fix it if you want to open up the servo.
take out the 4 screws that hold the front cover on and recenter the potentiometer. you need to remove all of the gears and turn the black pin until the motor stops turning. then re assemble the servo and see if that helped. if not you need to return it.
NEVER UNDERESTIMATE THE POWER
ABC CRP problem: Turn left when accelerate ikinari ABC DTM Electronics 25 05-10-2004 03:04 AM
wheels turn but car wont?? Spanky Bit Char-G / MicroSizers 4 02-24-2003 02:54 PM
My microsizer only wants to turn left!!!! Deadite Bit Char-G / MicroSizers 2 10-02-2002 03:10 PM
