Old 01-10-2004, 09:37 PM
viperdout's Avatar
It's Really Fast!
Project: X-Mod killa'
I just got my car back from micro_Amps today, and this thing's fast. This car is now going to turn into my new project, which is trying to beat an Xmod. Anyone know how fast one of them goes? I'm also going to order a 4.2. I have 2 120 mah cells lying around, so they're going in. Let the modding begin. By the way, thanks, micro_Amps!
Project Bad Brushless:
Just say no to giant sigs.
Old 01-11-2004, 08:37 AM
Comrade_Boris's Avatar
Confirmed: Lost In Fog
i should check how fast my skyline goes.....
with or without the body shell? its a hell of alot faster without the shell.....
i have stage 2 motors, AWD, and one sweet paintjob.....
-Andres
Old 01-11-2004, 08:47 AM
viperdout's Avatar
It's Really Fast!
No, outta the box stock. My friend got a radar gun and claims his one with stage 2 motors and other stuff did 20 mph.
Old 01-11-2004, 09:02 AM
ok...if your talking stock, you will kill it.....my bB killed my xmod when it was still stock, my bB has a 4.2 and single 120mAh batt......
-Andres
Old 01-11-2004, 10:12 AM
viperdout's Avatar
It's Really Fast!
Well then, stacked FETs and a dual cell (just did it) should rape an X-mod. Project done. This car has also gotta stay on carpet, because it's almost uncontrollable on wood floors.
Old 01-11-2004, 07:32 PM
enuke55 enuke55 is offline
Ya sure...
My X-Mod goes about 23mph, its got a 6 cell upgrade stage 2 AWD,tires, rims,bodykit A stock X-mod goes about 9mph. but a stage 2 with only RS upgrade hits about 15mph
My X-mod for sale-http://tinyrc.com/forums/showthread.php?s=&threadid=18845
Old 01-12-2004, 05:42 PM
viperdout's Avatar
It's Really Fast!
Well, I'm trying to get an RS employee to race me. It's going down soon!
Old 01-15-2004, 08:17 AM
ZZRACERX ZZRACERX is offline
No Max, YOU are going down. Next DDay, Cicco.'s class. BE THERE. lol
Tengo dos gatos muertos en mi pantalones.
Old 01-15-2004, 09:18 AM
charliebrown's Avatar
ViperDout: If you want to kill a stock Xmod, then here are my tips and suggestions.
Don't go for the 4.2's, they aren't that good, from what I hear. By a Phast motor from www.RCmod.com , They have great torque and lightning speed.
Go to Toys R us, or KB toys, and buy a KIT racer. Make sure it's the one with the green gears. Take the axle, and trim the spacer (opposite side of the axle gear) and make sure it will fit in your ZipZap. then, install the KIT racer gearing set (use the white pinion and the correct KIT gears).
As for the dual cell: You may or may not want to do the Layman's Tricell. I've heard from some people that they have done a regular dual cell and it beats the tricell. Do whatever you wish, but I'd recommend doing the Layman's Tricell and peak charging it at a rate as low as you can go, like 40-200 ma. I use a 300 ma, multi voltage AC-to-DC adapter from RadioShack. I charged the car for about 9 minutes (while watching a scene from 2 Fast 2 Furious to pass the time ) and I got a 5 minute runtime, but the car peformed like a tricell. You may want to parallel 2 of the Tricell packs to get 80 mah, for more torque and energy.
For the tires, you might want to use slicks all around. Make sure the surface you are racing on is clean like a whistle, so you have good traction, but not too much or you'll flip But in that case, just use a flip bar.
Good luck! I calculated that with the setup I mentioned above, you should rev that ZZ up to......Um...well, calculate for yourself, you won't be disappointed, the setup I mentioned should beat a fully tricked out Xmod!
Here are my calculations:
Phast motor: around 40,000 rpm, divided by 2 with load, times 3 with the tricell, equaling 60,000 rpm while running in the car on the ground.
60,000 divided by 3.43 (the KIT racer gear ratio)= 17492.7(and a bunch of other decimal numbers) wheel rpm.
Wheel rpm times 4 (wheel circumference in centimeters)= 69970.8 centimeters per min
Take that number, divided by 2.5 to convert to inches, then the result divided by 12 for feet= 2332 feet per minute
2332 times 60 for feet per hour, then divided by 5280 to get miles per hour= 26.5, that should beat an Xmod fully tricked out.
Yes, I am CRAZY!!!!!!!
Chuckster...
Old 01-15-2004, 12:11 PM
viperdout's Avatar
It's Really Fast!
ZZRACERX,
Next CAD club. Be there, or be square.
Old 01-15-2004, 12:14 PM
viperdout's Avatar
It's Really Fast!
Carliebrown, you are one sick person! I'm definately doing that! Wooo!!!!!!
Old 01-15-2004, 12:23 PM
Oh, and I just realized something. remember how I said that the motor rpm would be cut in half because of the load? That's with the normal transitors, but if you are using FETs, then the speed would be double what I mentioned! However, with that speed, your car will run out of batteries faster than the speed itself. So, even if you peak charge it, it's still going to suck because of runtime and enery being consumed.....But, go for that speed, and fly it off a 2-feet wide, 3-feet long, 35 degree ramp! RIDE 'EM COWBOY! WOOOO HOOO!!!!!
Chuckster...
Old 01-15-2004, 01:29 PM
viperdout's Avatar
It's Really Fast!
I can see the carnage now...
Old 01-15-2004, 01:35 PM
Yo viper the only carnage I can see is you crashing into the tables at the end of the hall my friend! MUHAHAHAHAHA!
Old 01-15-2004, 01:52 PM
viperdout's Avatar
It's Really Fast!
Dude, save that for the track! This is forum about how to kick an Xmod's butt, not trash talking. You wanna talk smack, PM me. BTW, I think I'm gonna try it. Oh, and shut up, freshman.
My first wheel mod project. (On my Yenko Camaro) Bad Company ZipZaps 14 05-21-2003 06:12 AM
My first mod project. Bad Company ZipZaps 25 05-08-2003 06:09 PM
Paint mod project for my new BitCharG Skyline slippers2k Bit Char-G Mods and Projects 11 10-17-2002 02:27 PM
