Old 01-10-2004, 05:34 PM
FenderdudeRRT FenderdudeRRT is offline
Help me please! got a fairly simple problem
hi guys i have noticed that on my xmod when i drive it fast, itll go crazy when i turn it not liek crazy turning just real light to keep it on a straight track. now, if i put the remote on fast, and go as fast as possible it just starts spinning around going crazy. COMPLETELY crazy. could this be the tired? im doin this on wood floor and their the stock tires? i also took it outside and it is not as bad on the concrete but still spins aroudn alot when turning. i think it might be the tires but im really not sure. i had a skyline before that ran fine with stock tires but now that i got the white supra, its been actin up liek this since the start. i appreciate the support thanks
XModS Gloss white Toyota Supra
SII drag motor
Wild style body kit with custom spoiler
Rayovac AAA IC-3 rechargables!
Eibach stiff and soft suspension
Tire Uprgrade
command lites
What is the Matrix?
Old 01-10-2004, 07:22 PM
Joey's Avatar
Joey Joey is offline
Hardwood floor, stock tires, yeah - that's not going to give you much traction. Try accelerating slowly, then going full-throttle after you're already moving. They're twitchy and uncentered by nature, so it's going to spin a little no matter what, but it'll at least go sort of straight.
Mazda Savanna RX-7
stage 2 motor | spaced wheels
Old 01-12-2004, 12:34 AM
spitty12's Avatar
spitty12 spitty12 is offline
Happiness is a warm gun..
Send a message via AIM to spitty12
The rear end of your car could be out of alignment. My left tire will come off the ground before the right one causing the inside wheel to lift around left handed turns and the car will spin. This is due to the rear back (black) plate being warped. I used aluminum foil spacers under the 3 position mounting point on the right side of the car to even it out. Lift the rear end of your car off the ground and which ever tire stays on the ground longest needs to have spacers(foil) put in the mounting points.
Old 01-19-2004, 05:33 AM
codedat
I would make sure the battery holders are on the last setting to place them close to the rear wheels. Also I would use the soft springs in the front and medium in the back. I run mine on a waxy tile floor and it work great.
i think i have a problem HebrewHammer ZipZaps SE 10 12-21-2003 04:13 PM
A problem with my mini-x RX and TX Smurf Mini-X 0 12-02-2003 10:32 PM
sputtering problem with my new zap... Cool Dad ZipZaps 12 06-20-2003 11:05 PM
Dogbones popping out? No problem. bluemax_1 Mini-X 3 04-01-2003 10:39 PM
Transmitter problem (picture included) ryanhook Bit Char-G / MicroSizers 11 12-26-2002 08:29 PM
