01-08-2004, 09:21 PM
how do you hook up a 180 motor
ive got a ff-180ph motor and i was wondering how to connect it to my xmod i have a civic if that makes any difference ive dont the SB, SB hybrid swaps but the 180 doesnt have room for the end cap so i was thinking i just need to hook up the red and black wires directly from the clip to the motor without the rest fo the electronics is that true? thatnks for any help in advance
01-08-2004, 09:46 PM
Mad Scientist
You need to remove the front motor mount, and solder on a connector from an XMods motor.
01-08-2004, 09:52 PM
but how there are 2 prongs on the back of the 180 do it just hook up the red and black wores to those?
01-08-2004, 10:15 PM
RC Tinkerer
Yes you would, however keep in mind, if you wire it backwards the car will respond backwards to the remote. So if you pull the trigger and the car goes in reverse, you will need to flip the wires around then.
01-08-2004, 10:28 PM
ok cool so should i just switch them from the way they are now? by the way this motor came out of an electric shaver
01-13-2004, 06:15 PM
BACK BEEEEEEEEEEECH!!
this is weird... first spinbrush motors, now shaver motors......
i don't think a shaver motor will have a lot o tourque (sp), though... because it doesnt really need a lot of power.
for shizzle
01-13-2004, 07:31 PM
You never know.
What kind is it out of, exactly? It's kind of weird how well-adapted the Sb is to XMODS, maybe there are all kinds of other applicances we haven't discovered yet.
Mazda Savanna RX-7
stage 2 motor | spaced wheels
01-13-2004, 07:54 PM
its out of a remington beard and mustashe trimmer it has way more torque then the SB cuz when i tested it with a 2cell AAA holder the motor fliped over where as the SB didnt the pinion just turned
01-14-2004, 06:36 PM
hmmmm.... i wonderif a dremel motor would work....
those are powerful.... i wonder if neuro could use his voltage meter thing to find out how much power the motor uses in a dremell..
for shizzle
01-15-2004, 02:07 AM
Happiness is a warm gun..
A dremel motor would just fly, lots of torque and high speed but I think they are pretty big. I think mine must be a lot bigger than a 180
01-15-2004, 02:11 AM
dremels use 4 rechargable double A's it looks like i just checked mine but im not sure what kind of motor it is if mine ever craps out i'll take it apart but i just cant see destroying a perfectly good one
01-15-2004, 06:35 AM
yeah, theyre kinda expensive
for shizzle
