Old 01-07-2004, 05:09 PM
micro kid's Avatar
micro kid micro kid is offline
Do you getto dremel?
mock wheelie bar
heres a tut. on how to make a decent looking wheelie bar.
Materials needed:
two tech deck wheel nuts
one tech deck wheel
one paper clip
pliers with wire cutters
knife or reamer
1 straten the paper clip
2 find the center of the paper clip
3 put the wheel in the center of the clip and bend the clip so the wheel stays and bend the ends of the paper clip up so they will fit into the holes in the rear of the chassis
4 use your reamer or knife to enlarge the holes to just smaller than the tech deck nuts
5 press the nuts into the holes and make them sit flat in the chassis
6 trim the wheelie bar to the lenghth you want
7 bend the open ends of the bar so they are wider than the gap between the holes
8 mount your body and clip the bar in and bend to the look you want
9 drive
racing on pavement is for wussies.
Old 01-09-2004, 06:22 PM
lam lam is offline
Send a message via Yahoo to lam
hey thats a kool mod i havent tried it yet but i will try later
Old 01-09-2004, 06:30 PM
micro kid's Avatar
thanx
you should try it. just dont squeeze the wheel too much in the pliers when you bend the wire around it i broke one of my wheels doing that
How to make a wheelie bar. moshbmxa Bit Char-G / MicroSizers 0 07-18-2003 11:05 AM
Hotwheels wheelie bar trinitron2k2 Bit Char-G Parts and Hop-Ups 3 02-14-2003 05:25 AM
does any1 have an extra kit racer wheelie bar ronak26 Bit Char-G / MicroSizers 0 01-12-2003 03:59 PM
bit char g wheelie bar striderpunk Bit Char-G / MicroSizers 2 10-19-2002 03:27 PM
wheelie bar JaMeZzZ122 Bit Char-G Mods and Projects 8 09-27-2002 02:28 PM
