Old 01-06-2004, 07:02 PM
rmyc's Avatar
rmyc rmyc is offline
Perfected Bit Modder
CUSTOM R/C needs ESC SETUP HELP
hey guyz a bought i cheap 2-aa rc car but then it was hella slow so i decided to upgrade it to 4-aaa and a stock mini-z motor
300% improvement
Old 01-06-2004, 07:05 PM
rmyc's Avatar
but that still wasnt enough , so i decide to use my new mini-x electronics that a had for over a year and a tamiya hyperdash motor .. and all i could say is wow... it supper fast now .. it would easily lap a mini-z and eat the xmods for lunch...
but only one problem is i forgot how to set up the esc..( i'm using the kyosho controller..) i got it to work last year but i kinda forgot ...could any one help me? thanks
Old 01-09-2004, 07:42 AM
e_lm_70 e_lm_70 is offline
The Kyosho TX is not good for the Mini-X ESC ...
Kyosho TX send a signal that is slightly in a wider range that is expected ... as result it will be difficult to avoid from a full forward to a fullreverse, when the upper limit is reached !
Need a new TX or put something for reduce the travel of the TX gun !
e_lm_70
Old 01-10-2004, 04:25 AM
cdog4w's Avatar
cdog4w cdog4w is offline
newbmaster
setup instructions
Following is copied from rcmart.com (easier than me typing it out from my printed instructions). They also have a link to full setup instructions, but apparently that was hacked. No joke, go to the link below, then go to the "Mini-X ESC Calibration" link and you get the page that simply reads "TechTeaM haxoring Or box!" MMM box...
SETUP PROCEDURES:
1. Turn on the transmitter(TX.).
2. Turn on the electronic speed controller(ESC).
3. Press the ESC setup button with provided plastic mini screwdriver (use metal screwdriver will easy damaged to the ESC.) For 2-3 seconds until both red and green light off and release the setup button.
4. Wait until green light off and red light still on, press the TX. throttle stick to full forward position when the red light still on and remain the throttle stick in full forward position and wait until green light on and red light off, press the throttle stick to full backward position until the motor going backward.
5. Release the TX. throttle stick and the whole procedure finished.
http://www.rcmart.com/catalog/produc...oducts_id=2407
My rides:
RS Stg II 12 25 setup jnkyrdstng XMODS Mods and Projects 0 03-02-2008 01:31 PM
Directions on Avatar, and Custom Title MicRoMaN TinyRC.com Shop Support 11 09-10-2006 10:24 PM
esc setup sucks helldriver Mini-X 4 07-03-2003 01:40 AM
R/C battle AnTboTs slotsurfer Other Tiny RCs 5 12-15-2002 03:53 PM
