Old 01-06-2004, 03:53 PM
chimchim chimchim is offline
Unhappy Pulsing acceleration
I just bought my first XMOD (black civic) and played around with in a bit in the parking lot. Everything seems to work fine except when it gets more than 5 feet away from me the acceleration seems to pulse... as if I was rapidly pressing and releasing the throttle. It still accelerates to speed but it's like the "little driver" inside is have a leg seizure with his gas pedal foot.
Anyone have this problem?
(BTW, the terminal connecting to the antenna was covered with gucky electronic flux like material... I scraped it off for a cleaner contact, but maybe I didn't scrape it well enough?)
Old 01-06-2004, 04:18 PM
Joey's Avatar
Joey Joey is offline
You could either be getting interference from an outside source (especially since it's in a parking lot), or your signal transmission may not be coming through clearly enough. This could be because the batteries are going dead, or there's simply some electrical problem. I've never heard of flux being on the antenna..that could be a rather bad sign. Not that it would directly hurt anything, but it could be defective or something.
Mazda Savanna RX-7
stage 2 motor | spaced wheels
Old 01-07-2004, 08:36 AM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
what is flux? the core of the solder that RS used?
NEVER UNDERESTIMATE THE POWER
Old 01-07-2004, 11:01 AM
tavisjohn's Avatar
tavisjohn tavisjohn is offline
RC Tinkerer
Yes, you are correct.
I reccomend you clean the antenna connector. That should help.
Idea for Acceleration Steve ZipZaps SE 15 02-10-2004 11:25 AM
Acceleration Char-g Ace ZipZaps SE 1 10-06-2003 12:53 PM
Proportional Acceleration?? djmr2 Digi Q 1 02-11-2003 09:45 AM
Slow Acceleration Spitfire7001 ZipZaps 6 10-08-2002 08:07 PM
Pulsing Tx Mod? tinyrc Bit Char-G / MicroSizers 0 07-03-2002 12:10 AM
