Old 01-05-2004, 06:40 PM
Gaian's Avatar
Gaian Gaian is offline
I must be Nuckin' Futs!!!
Send a message via AIM to Gaian
Lightbulb Antenna wire fix
As many of you already know, the antenna wire isn’t held together with much. The terminal at the end of the wire just fell apart on mine. I looked at the solder job on it, and there was barely anything there.
So, what I did was take a piece of that heat shrink tubing that they supplied us with (the little tubes on the end of the axle’s) and slipped the thing over the wire, then re-soldered the wire back on. Then I slid the tubing up to cover the wire and the solder (but left enough room for the screw and antenna to make contact) and shrunk it down.
That thing isn’t coming apart anytime soon now.
Old 01-05-2004, 07:24 PM
red_dragons_01 red_dragons_01 is offline
Send a message via AIM to red_dragons_01
hey maybe you can help me.... my attena wire came off and i see no solder where it might have been can you please tell me where to solder.. thanks
Antenna Wire/ Battery Short..!.. rplpt XMODS 2 01-04-2004 09:55 AM
Speaker wire antenna xc/zz ZipZaps SE 9 12-21-2003 01:44 PM
Wire problem...how do i fix it?!?! dmoh7 Bit Char-G / MicroSizers 21 07-18-2003 12:49 AM
26 / 24 / 22? What wire size for the antenna? AceQ Bit Char-G / MicroSizers 1 10-22-2002 05:01 PM
