Old 01-04-2004, 02:04 PM
rsxracer90 rsxracer90 is offline
Send a message via AIM to rsxracer90
Lightbulb under glow and better showing lights.
go to this web site for more instructions. http://www.geocities.com/jeromebrill/neons.html and for the better showing light get some aluminion (< cant spell) and get ur back lights take them out the plastic thing and cut out the foil to match it. then jus glue it in to the place. turn on ur lights. and wala. i did it to mine it looks like crome. http://www.geocities.com/jeromebrill/neons.html
Old 01-04-2004, 02:05 PM
if u did it right. show me a pic when done.
Old 01-04-2004, 02:24 PM
im me at aim athr90
Old 01-04-2004, 02:53 PM
QPizzle QPizzle is offline
Send a message via AIM to QPizzle
i knew i saw that car somewhere else.. in the ****rc.com show gallery.. thats one of the nicest looking stock cars ive seen. where did you get the wiring.. is that pc mod wiring or street glow? where did you get it and is it possible if i can order it online.
Old 01-04-2004, 03:42 PM
that is not my car. the guy i got this website from, that is his car and his website. he told me about this. so i passed it on. im a begginer at this xmods stuff so bare with me.
Old 01-04-2004, 03:48 PM
aero528's Avatar
aero528 aero528 is offline
like my dog??
Send a message via AIM to aero528
he got it out of a ps2 controler. my Q is can i still use the cotroler for my ps2? if i can i might consiter doing this.
--Chris
Aka...aero528
Old 01-04-2004, 03:53 PM
yea probly after all its jus the lighting, shouldn't stop the whole controler.
Old 01-04-2004, 07:04 PM
Joey's Avatar
Joey Joey is offline
Provided you can remove and reinstall the L and R buttons without harming and attached circuitry, which I would guess is totally possible. I think this is a better idea than the HottWirez; it requires less power and fits right into the stock light outlet. I'd still have to find a way to use the head- and taillights.
Mazda Savanna RX-7
stage 2 motor | spaced wheels
Old 01-05-2004, 04:17 PM
u hav a point. cause when u install the neon u must take out the light to do so. mabye if u somehow connect both at same time like an extension cord with multiple plug in spots. but how to do that. ill go back to the drawing board.
Old 01-07-2004, 06:30 PM
Darklancer's Avatar
Darklancer Darklancer is offline
Send a message via AIM to Darklancer Send a message via Yahoo to Darklancer
Cool How to Have underbodies and CL lights
All u would have to do to get the command logic lights is to buy them for the car and use that connector. Simply strip the insulation from a small part of the wire without severing it (I think a hobby knife would do well) and attach the neon wires as instructed, however this would drain more power so u should use it for show unless you have a higher (6 normally) cell upgrade. Then to prevent shortage use some electrical tape.
Just hope I could b of help
Wandering through the cold, dark world, I stand alone. Silent screams fill the tainted air and blood drips endlessly from branches of leafless trees. I stand at the edge of an endless cliff and mutter silently to myself as I look upon this lifeless planet. "This is not my home."
^I made that up.
Old 01-07-2004, 09:04 PM
Joey's Avatar
You could use that idea with the normal four cells, the lights just wouldn't be as bright. Someone ought to test that; might not look too bad that way.
Mazda Savanna RX-7
Old 01-08-2004, 07:00 PM
Darklancer's Avatar
If I can make sum $$ I'll try it, gotta shovel sum driveways! lol
^I made that up.
Old 01-09-2004, 09:00 PM
KnotHole's Avatar
KnotHole KnotHole is offline
JesUSAves
Thumbs up ...PS2 Controler
I went to "RS" a couple of hours ago and checked out the controler. I could only look at it through the package but it does look like it would be VERY easy to remove the light in it. And it also looked like the controler would work just fine after the light was removed. I think this is the best light i've seen for under-body glow. I wish it came in other colors. I think it only comes in blue but thats alright with me... Thanks for the info on this light.
One more thing...Does anyone think that this light might be able to work off of one of those large flat batterys that some people use for there LED's ??? If it would work then we could still use our head/tail light kits !!! I'm just not 2 edgamakated when it comes to electronics. Can anyone help out on this ?
Old 01-10-2004, 05:04 PM
Darklancer's Avatar
I think you could run it off of one or 2 of those, because they have pretty good power (around 3 v) but i don't think it would run 4 long, The process I explained above isn't that hard tho.
^I made that up.
Old 01-10-2004, 07:21 PM
Joey's Avatar
Re: ...PS2 Controler
I was picking up some washers and nuts today, and I saw a red one. I didn't realize that they were such tiny little things!
Mazda Savanna RX-7
