Old 01-03-2004, 09:36 PM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
Please Help
i ordered:
12414207 - PCB ASSY RECEIVER $9.49
12414215 - SERVO ASSY $8.69
last week and i need to know where the 2 wires coming off of the servo motor are soldered on and where the battery wires are soldered to. (ex: red front hole, black back hole)
NEVER UNDERESTIMATE THE POWER
Old 01-03-2004, 09:44 PM
Bad Company's Avatar
I'm not sure which (2) servo wires you are talking about, but here is a pic. The white arrows show where the red and black battery wires are attached.
Old 01-03-2004, 09:49 PM
aperson's Avatar
thank you BC. if you look at the servo there are 3 wires that go right by each other. then there are 2 wires a blue and a red one. i needed to know where they went. thanks again
by the way like what ive done to my ZZ?
Old 01-05-2004, 05:49 PM
aperson's Avatar
ok i wired it up like the picture but the new one isn't working. if i go to my RS and ask them if they have an extra crystal set to see if thats the problem will they give me some? i dont mean the upgrade just another stock set.
Old 01-05-2004, 06:04 PM
tavisjohn's Avatar
tavisjohn tavisjohn is offline
RC Tinkerer
Most RS stores will not have any small replacement parts on hand. If you want it now, you may have to get the Crystal Set. If you can wait, then you can order the stock ones from 1-800-the-shack. (See CJ's FAQ)
Old 01-05-2004, 06:21 PM
aperson's Avatar
ok but is there anything else that could be wrong? could it be defective?
EDIT: could the PCB or servo be defective?
Old 01-05-2004, 07:26 PM
aperson's Avatar
please i need help!
Old 01-05-2004, 07:48 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
well how are we supposed to know if it's defective or not? anyway, check your connections to the board with BC's pic. then make sure you get all your other connections are good like to the battery,motor, antenna, etc
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 01-06-2004, 09:24 AM
aperson's Avatar
i found the problem my dad wanted to see it and he broke the 3 wires going to the reciever pcb. had to find a really tiny wire stripper and resolder them back on. thanks
Old 01-10-2004, 06:10 PM
rplpt rplpt is offline
Sup Dude
Send a message via AIM to rplpt
2 Servo Wires
Exactly where do the 2 servo wires connect to. What part of the chip.
Does it matter where you solder 'em on..??..
Old 01-12-2004, 09:23 AM
aperson's Avatar
there are the 2 mosfets (big black chips) and there is one wire going to each one just solder them onto where the picture shows. it SHOULDN'T matter where though.
Old 01-12-2004, 12:49 PM
neurokinetik's Avatar
Mad Scientist
Re: 2 Servo Wires
The whole one side of those chips are all the same connection. Just solder the red wire to the one chip, and the blue one to the other, it doesn't matter which pin, as long as you are on the side of the chip shown in the pic.
Old 01-12-2004, 08:53 PM
aperson's Avatar
why would they all go to the same place?
