Old 01-02-2004, 07:05 PM
Bad Company's Avatar
BC's Xmod Masking/Painting Tutorial
Let me start out that this how I do it, and you have seen the results before.
The materials I prefer to use are:
Tamiya Masking Tape
Tamiya Grey Primer
Tamiya TS# Color Paint
Tamiya TS-13 Clear Coat
You can use other brands, but I would at least reccomend using the same brand primer, paint, and clear coat.
Other tools & materials:
X-acto Knife or Hobby Knife
Dremel or Hobby Knife
Dish Soap
Cup or something to sit car body on.
Something with a small flat edge. (I use the Zip Zaps screwdriver built into the controller.)
Very thin clear double sided tape.
Remove the headlight and tailight lenses:
1. Use the Dremel or hobby knife to scrape away at where the little tabs from the lenses are melted to the inside of the body. Remove enough untill you see just the round shape of the tab itself.
2. Gently push the tabs outward from the body by alternating between the 2 tabs a little at a time for each lense as not to bind the lense or crack it.
3. Clean off the tabs edges for easy reinstallation later.
Make sure all body parts are tightened down:
1. I paint all my bodies in one piece. If you prefer not to, then dissassemble them now.
Wash body and body parts:
1. Run the body or body parts under warm water and add a little dish soap and throughly wash body parts.
2. Rinse away ALL soap with warm water.
3. Let parts air dry completely or use a lint free rag to dry.
4. Make sure no water is in any cracks or openings.
Masking of windows and other parts.
1. Apply the masking tape so that it overlaps the window edges.
2. Use multiple pieces to cover entire window by overlapping each piece.
3. Press all tape firmly down around all edges.
4. Use that flat edge to gently press the tape down into the window edges where you want to cut. I go along the edge in steps instead of dragging the flat edge which may cut in to your tape wrong.
5. Use your X-acto knife and follow the groove of the window edge and cut out your window mask.
6. Remove the tape on the outside of the window edges.
7. Press down the edges again to insure no bleed thru.
8. Repeat the process for all windows.
For masking vents, etc. use the same techniques by pressing your tape into the corners and cutting along those lines/corners with the X-acto knife.
Setting body up for painting:
This is for painting the entire body in one piece like I do. If you paint the body kit parts seperately, then you must find a way to secure them.
1. Turn the cup over and apply your masking tape over so that the sticky part is facing out.
2. Stick the body over the cup bottom and make it secure to the maskingtape.
3. Make sure body will not move at different angles.
Applying paint: All distances and times are based on Tamiya paint. Othe paint my dry slower or be thicker and require more time or farther spray distance.
I always heat my cans up in hot water for about 10 minutes, not higher than 120 deg, F. This thins the paint out and builds pressure up in the can for better flow when spraying. Remember to shake your can good to mix up the paint.
Applying primer:
1. Make one very light pass on all sides from about 12" away with a semi fast motion. This lets the primer seal the edges of the masking tape and prevent bleeding.
2. Wait 5 minutes.
2. Go back with 2 good coats on all sides from about 12", but a slower motion. 10 minutes in between each coat.
3. Make sure the entire body is covered including vents and openings. You may have to spray from different angles.
Let primer dry 10 minutes.
Applying color coat:
1. Use the same techique as before, starting first coat very light.
2. Wait 10 minutes and apply the second coat a little heavier from 12" away.
3. Wait 10 minutes and repeat on all sides.
4. Wait 10 minutes and repeat.
5. I usually do about 5-6 color coats, 10 minutes between.
Let color coat dry 10 minutes.
Applying clear coat:
1. Apply one light coat from 12" away on all sides.
2. Wait 10 minutes.
3. Apply second coat a little bit heavier from 12" away.
4. I usually put 2-3 good clear coats on it.
Let everything dry untill it is still a little bit tacky. Thhis is where some will dissagree and say let it dry completely, but I have good success removing the tape before it is completely dry. It is your choice. Sometimes the paint will crack on the edges when it is completely dry.
Removing the masking:
1. Take the point of your X-acto knife and gently pick one corner of you masked window, etc. and slowly pull away the tape until you can grab it with your fingers. The slowly pull away the rest.
2. Use something with a clean straightedge to psh down any ridges as a result of the mask line. Don't rub, but use "steps".
3. Continue on all masked parts.
Let the entire body completely dry. (Tamiya usually is good to handle after 6 hours.)
Paint the details:
1. Use a hobby brush to paint your details like the headlights and tailights and markers.
2. Only a steady hand can help you here. What I do is hold the brush in one hand, and the model in the other and interlock my my remaining fingers from each hand. That way, if one hand moves, everything moves together and I am less likely to mess up.
Reinstall the lenses.
1. Cut up small pieces of the very thin clear double sided tape and apply them to the corners of eac lense.
2. Push the lenses back into place.
3. You could skip the tape and just add some glue to where the tabs stick thru the body on the inside.
You're all done.
Painting fades:
Here is how I do it with rattle cans....
Top to Bottom Fade:
Spray the first color from an angle underneath the body moving up and pulling the can farther away as I approach the fade line. Then use the second color, doing the same from above. Not much else, just takes practice. You can use a piece of cardboard to control your spray pattern too. Just hold it along the line you want to fade slightly above the model, and the paint will kinda sneak under the cardboard. The closer you get, the more it will sneak thru.
Front to Back Fade:
Same as the Top to Bottom, but going side to side. One color from a fron angle pulling back as you get closer to the rear, and the other color from rear angle pulling back as you get closer to the front.
Sometimes I spray a third matching color from way far away to add little speckles that mix into both colors and bring the blend together more.
Hope this helps!
There may be mistakes until I read thru a few times.
Old 01-02-2004, 08:12 PM
10_second_supra 10_second_supra is offline
xmod destroyer
nice work bc how do you heat up your cans
350z-SS 130 motor, bearings cf driveshaft, custom paint,
supra- high torque 180, 6 cell bearings,
civic- powerdash, bearings,cf driveshaft
rsx-fried
4supras fried
2 skylines detroyed
1 civic destroyee
Old 01-02-2004, 09:00 PM
Stuck a coffee mug 3/4 full of water in the Microwave on high for 45 seconds.
Old 01-02-2004, 11:03 PM
Rx7NoZ's Avatar
Rx7NoZ Rx7NoZ is offline
thanx alot man im doing it tomorow i got the paint already
Xmod:
Civic (black)
Stiff Suspension
Awd
White side skirts,White Carbon fiber hood,White rims and Drop
Old 01-03-2004, 03:17 PM
aero528's Avatar
aero528 aero528 is offline
like my dog??
Send a message via AIM to aero528
Re: BC's Xmod Masking/Painting Tutorial
Originally posted by Bad Company
...Only a steady hand can help you here. What I do is hold the brush in one hand...
do you use masking tape around the areas when you hand paint it? wouldent that help with getting the edge you want?
--Chris
Aka...aero528
Old 01-03-2004, 04:08 PM
Re: Re: BC's Xmod Masking/Painting Tutorial
No, I use a #0 brush and the technique I described, but that is a good idea if you don't have a steady hand.
Some things are not worth the trouble masking like the countours around the headlights, etc.
Old 01-03-2004, 07:35 PM
suprafreak33 suprafreak33 is offline
got supra?
isnt metal in a Microwave a bad idea??
xmod
blue supra
6 cell
all upgrades[by rs]
Old 01-03-2004, 08:22 PM
The coffee mug wasn't metal. Stuck the paint can in after I took the hot water out of the microwave.
Old 01-04-2004, 05:07 PM
got supra?
OH OK thanks
xmod
blue supra
6 cell
all upgrades[by rs]
Old 01-05-2004, 09:39 PM
brightsons brightsons is offline
Thanks for the great tutorial. When I buy another body for my xmod I will definitely paint it using your method.
If its not too much trouble could u also post pics with the steps. You don't have to do it but I would really appreciate it and it'll definitely make things a little easier for noobs like me and others to the xmod painting scene.
Old 01-08-2004, 12:12 PM
neurokinetik's Avatar
Mad Scientist
For Testors paint, the time between coats is more like 30-40 minutes, and you have to be very careful when spraying it, as it runs easily.
Wait 48 hours before spraying clear over any Testors color, or else it may bubble.
Testors does not require primer.
Old 01-08-2004, 03:21 PM
Exaran's Avatar
Exaran Exaran is offline
Send a message via AIM to Exaran
I painted my whole car body color first, then masked the body and painted the windows black. If you mask the windows first, you may get rings of the old body color around the windows if you are off with your mask even a little
Sliver Xmods Skyline
SB hybrid S1 drift motor - Yay doughnuts!
Old 01-16-2004, 08:50 PM
Darklancer's Avatar
Darklancer Darklancer is offline
Send a message via AIM to Darklancer Send a message via Yahoo to Darklancer
Hey, For a really good painting stand, I used the platform that held the body when you first buy the car, it works excellently, and the car stays in place. Just rip off the 'wall' on the edge and you can paint all sides easily.
Wandering through the cold, dark world, I stand alone. Silent screams fill the tainted air and blood drips endlessly from branches of leafless trees. I stand at the edge of an endless cliff and mutter silently to myself as I look upon this lifeless planet. "This is not my home."
^I made that up.
Old 01-17-2004, 09:23 AM
Very good tip!
Old 01-18-2004, 01:51 PM
nobodyhere962's Avatar
nobodyhere962 nobodyhere962 is offline
Honda 4 life
Send a message via AIM to nobodyhere962
i didnt get the clear coat yet but is it glossy
just checking before i get it
"Why do they have locks on the doors for stores that are open 24-7?"
that counts holidays too!
A new Question every year i think!
Xmod Evo Truck HD Dogbone Mod CinnaBun XMODS Mods and Projects 0 02-03-2006 10:07 PM
I Have An H-bridge Install Tutorial...need Pics Authorized Jshwaa XMODS Mods and Projects 13 11-08-2004 05:43 AM
Xmod Monster Tires Tutorial JesterDotcom XMODS Mods and Projects 7 07-18-2004 01:08 PM
BC's Xmod Gallery Bad Company XMODS Gallery 79 11-13-2003 02:14 AM
