Old 01-02-2004, 01:43 PM
backtrack9's Avatar
backtrack9 backtrack9 is offline
sLoWly gOInG iNsAnE
New 6 Cell Idea!
Ok everyone, I just came across an interesting find. To my knowledge all of the 5 and 6 cell modifications have been done so far by simply adding on an additional AAA battery holder to the circuitry. If using NiMH batteries this would put the total supply voltage up to 6.0V (for 5 cell) and 7.2V (for 6 cell) with a charge capacity of ~750-800 mah. While browsing the web I found another possible way to get the same voltage, but with less storage capacity. Take a look at www.batterieswholesale.com and find the 2/3 AAA NiMH cells. They are the same diameter as a AAA yet only 2/3 the length. This means you could mod the stock battery holders to fit 2 of these 2/3AAA cell into each slot that holds one standard AAA cell. This would give you twice the voltage, but it would also reduce the capacity down to ~300 mah (for 2/3AAA). Hey, at a higher voltage and a reduced weight who knows if anyone would have the endurance to drive a rocket around for 25 minutes anyway. This will reduce run time, but will be worth it for the gains in voltage without the need to add extra weight. Hey Neuro, this would work great for your dragster project. You could even use the 1/4AAA cells for a single run.
Two problems exist with this method. The first is the fact these cells are not button top like standard AAA. This means they will have to be soldered together (a tricky thing that could damage the batteries) like 1/10 scale RC cars. The other problem is the way in which they will have to be charged. They can not be removed and simply placed into a Rayovac charger. A hobby grade peak charger designed for use with NiMH cell will be the only way to recharge these things. At any rate, I still think it is worth a shot to try this. I have already ordered my set of 1/2AAA and 2/3AAA. I will let you know how it turns out.
Old 01-02-2004, 01:53 PM
neurokinetik's Avatar
Mad Scientist
Good idea. More weight reduction for the drag car.
Old 01-02-2004, 05:03 PM
newbitowner's Avatar
newbitowner newbitowner is offline
where can i get a peak charger online?
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
Old 01-02-2004, 05:04 PM
scott scott is offline
what do you think of li-poly's i got a few of the
2cell 250ma they half oz light and pack a good punch.
Old 01-02-2004, 06:05 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
2 x 2/3 = 4/3 a tad long to fit into the space of a AAA. only 1/2 AAA's would fit
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 01-02-2004, 06:30 PM
sinistar sinistar is offline
hey Neuro and Sono
sono
Team Orion Micro Elite Stock Motor
ITs the Team Orion Micro Elite Stock Motor
around 10-13$
Stock Number: RC-ORI 20901
its a 7.2 volt motor. so its running slightly under powered
Report this post to a moderator | IP: Logged
12-23-2003 07:57 PM
neurokinetik
Mad Scientist
I have been running one of those, along with the GPM modified motor. The Team Orion is really good if you take off 10 turns, and even better if you do that and then run it on 7.2V. The acceleration I get with this setup is astounding. I've drag raced a 1/10th scale AWD pan car and killed him for the first 10 feet, until he could get his speed up and blow by me. Oh, and that was with me running four cells and him running six. Next time, I will also be running six cells, and I think the driver will be somewhat surprised when I pull on him for the first 10 feet, then continue to pull away...
Stock, the Team Orion motor with only four cells and AWD is a killer combo on a road course.
OK HERE is the setup I have yet to try on my HB Two Tadiran AA lithiums. You can buy these batts at RS but they sell singly for 10.99 a piece you can also get from RS a Single AA bat holder. Now the voltage of the single tadiran AA alone is 3.6 Volts. 3.6 V + 3.6 is 7.2 volts the same voltage amount as the Team Orion Micro Elite Stock Motor. And it's only 2 AA's way less weight maybe this could work for that Drag project of yours.
Sinistar
question #6 is now ready out of the
toaster and has popped up for you.
Old 01-02-2004, 08:16 PM
backtrack9's Avatar
sLoWly gOInG iNsAnE
Two 2/3AAA cell will end up being about 7/16" too long to fit in the stock AAA holder. Solution: modify the stock battery holder. There is room on the XMOD chassis for this type of configuration. Another option is to orient them vertically and stack them side-by-side. Solder them together the same way you solder a 1/10 scale RC saddle pack. Use battery bars to connect them. The height of the cells is ~ 3mm taller than the width of the stock battery holder. All you need at that point is some planning and a Dremel tool. Next thing you know you will be zipping around at 6 cell speed with only 54% of the battery weight compared to using a 6 cell AAA set-up. Now, again this comes at a cost of run time. Oh well, speed is the name of the game, right?
Dual Cell Mod Tutorial And Idea!!! Snake Mod Bit Char-G / MicroSizers 11 11-13-2006 08:15 PM
Dual Cell idea Racer9 Bit Char-G / MicroSizers 21 04-08-2003 05:34 PM
quad cell funky a$$ idea mini rc man Bit Char-G Mods and Projects 1 01-29-2003 07:19 AM
