Old 01-01-2004, 07:55 PM
Shiporu's Avatar
Shiporu Shiporu is offline
I make great sandwiches
Send a message via AIM to Shiporu Send a message via Yahoo to Shiporu
Question Foglights....
Can anyone give me any ideas on making fog lights? I spliced 2 LED blue lights to my civic, but there was not enough power to lights the blue LEDs up....stayed dim.... do i need to re-route power to the blue LEDs?
My Xmod:
now has Tiny Rc parts and schools everyone here!!!
Old 01-01-2004, 07:59 PM
I Shall Return!
i honestly dont know, according to b.c.'s mod it should work... any way as a temorary fix you could use 2-3 watch batts for power.. hope this helps..
Old 01-01-2004, 08:06 PM
I Shall Return!
Old 01-01-2004, 11:53 PM
tavisjohn's Avatar
tavisjohn tavisjohn is offline
RC Tinkerer
What is the voltage output to the Light Kit's LED's? What is the power requirements of the blue LED's? If the voltage output is lower than the Power requirements of the LED then it will be really dim.
Old 01-02-2004, 03:39 AM
Shiporu's Avatar
xxspeednplayxx, thanks for the idea. I will try that.
My Xmod:
Old 01-02-2004, 03:42 AM
Shiporu's Avatar
tavisjohn, The power requirements for the blue LED's are 6 volts. so that would mean I have to add a 5th cell to car right?
because 4 cells=4.8 volts. Thanks for the help.
My Xmod:
Old 01-02-2004, 07:40 AM
Bad Company's Avatar
I would be real carefull about addding the extra cells to the car AND using the light kit. I haven't done it myself, but some have said it causes problems for your car.
Old 01-02-2004, 10:22 AM
tavisjohn's Avatar
RC Tinkerer
Measure the voltage to the light with a volt meter. Then get LED's that match that voltage. I would not reccomend that you try to match the voltage to the LED's you already have, you should match the LED's to the voltage that is already there.
Blue foglights... Shiporu XMODS Gallery 11 02-10-2004 05:41 PM
adding foglights to light kit arch2b XMODS Mods and Projects 29 01-18-2004 11:22 AM
custom foglights luislugo XMODS Gallery 10 12-22-2003 09:16 AM
