Old 12-31-2003, 08:08 PM
kasper01001's Avatar
kasper01001 kasper01001 is offline
("\(0.o)/") Rawr!
Send a message via AIM to kasper01001
sB motor question
um can you use any gear for them? also is it more torque or more power? or both? o yea whats a hybrid motor?
Xmod Parts Help
Old 12-31-2003, 08:47 PM
neo16769 neo16769 is offline
Yea you can use any gear wit em but i would suggest using the 11 tooth setup. I have my supra with the 10 tooth and civic with 11 tooth. The supra has too much wheel spin personally. Also the hybrid is when you use the back of the stock motor, ie. plastic part with the connections on it. At least that's what i did....
Old 01-02-2004, 04:06 PM
SuPrBuGmAn SuPrBuGmAn is offline
SB 130 = SB can, RS endbell, SB armature, RS pinion, SB magnets
SB Hybrid = SB can, RS endbell, RS armature, RS pinion, SB magnets
RS Hybrid = RS can, RS endbell, RS armature, RS pinion, SB magnets
I'm running the SB 130 with a drag pinion at the moment, I also have RWD so I figured the lower gearing wouldn't hurt my traction too much.
