Old 12-31-2003, 04:14 PM
nrsjs's Avatar
nrsjs nrsjs is offline
Mini-Z top speed comparison
I've been pretty suprised by the performance I was able to squeeze out of my XMOD, so I decided to compare it to some of my old specs from my Mini-Z. I used my Tamiya mini 4WD speed checker to check the speed, but I opened it up and removed the front wheel spinner because my xmod has awd and it just flies off the tester with the front spinner on there. This way the wheels are just spinning freely in the holes left there. Anyone with the charger will probably know what I'm talking about. The 'total cost' figures don't include money spent on battery recharger, spare batteries, aesthetics, etc
Xmod specs:
6 Cells, Blue Stage 2 motor, AWD, stock tires, I-C3 cells
Total cost: ~$110
Mini-Z specs:
4 Cells, PN SO2 racing motor, TLP Twin Turbo R, Racing Ball Diff, Kodac NIMH cells, also stock tires
Total cost: ~$170 (before lots of other money poured into stuff that doesnt affect these test results)
Xmod test results (with 6 cells):
Top speed: 37 kmh (23 mph)
100 meters: 9.62 seconds
Xmod test results (with 4 cells):
Top speed: 27 kmh (17 mph)
100 meters: 13.62 seconds
Mini-Z test results:
Top Speed: 28 kmh (18 mph)
100 meters: 13.43 seconds
Don't get me wrong, I love Mini-Z's, but XMODS are nothing to be looked down upon It should also be noted that the numbers would be even higher with RWD instead of AWD. And it also asks everyone with the 6-cell mod still on their 'to do' list: what are you waiting for? It really does make an astronomical difference!
Old 12-31-2003, 04:49 PM
Daazndood Daazndood is offline
are you serious a 6 cell xmod can beat a mini Z? thats so cool! thanks for posting this. this was exactly what i wanted to read.
what about 5 cell though?
Old 12-31-2003, 05:07 PM
Got 4.2 King? I do : )
also we have to look at the weight though. the miniz has a lower weight than the xmod so it will be closer to the time shown than the xmod. but the xmod has alot higher speed
MY XMOD!
Yellow skyline
Springs: Hard all around
1.5 degree toe in
hard slicks
Top Speed stage 2 motor
full bearings
AWD
6 spoke wheel upgrade
energizer rechargeables
6 Cell Upgrade
Old 12-31-2003, 07:07 PM
theMonster's Avatar
Got Brains?
accuracy
I was going to buy one, when I read on the dinball web-site a few reviews saying that it was not accurate when measuring the speed of the mini-z. This aside though, if you tested both the mini-z and the x-mod on this machine and saw that the x-mod was faster, this is comparing apples-to-apples.
This is your brain.....
Old 12-31-2003, 09:23 PM
RedRSX's Avatar
RedRSX RedRSX is offline
Subaru WRX STi
i gotta see it to believe it
Old 01-01-2004, 12:43 AM
neurokinetik's Avatar
Mad Scientist
I picked one of those up as well, and have been doing some of my own testing. I haven't had any big problem with the car staying on it when testing, either with RWD or AWD.
I did find that the AWD makes very little difference to the top speed in reality. 1Km/H according to my tests.
Here's what I found:
Tests made with AWD car:
Stage 1 drift (after water break in. This motor is noticably faster than the typical Stage 1 motor), 6:1 gear: 16-17kph (9.9 - 10.5 mph)
Stage 2 drift (bone stock), 6:1 gear: 19kph (11.8 mph)
Stage 2 drag (factory freak), 5.11:1 gear: 21kph (13.0 mph)
Team Orion stock 180 motor, 3.83:1 gear: 16-17kph (9.9 - 10.5 mph)
GPM Hi Speed Modified motor, 3.83:1 gear: 18kph (11.2 mph)
Stage 2 drag hybrid (timing advance and spin brush magnets), 5.11:1 gear: 21-22kph (13 - 13.7 mph)
Custom 35 turn, Neo magnets, BB can, timing advance, 4.4:1 gear: 25kph (15.5 mph)
Stage 2 reduced to 42 turns, timing advance, 5.11:1 gear: 22kph (13.7 mph)
In the RWD (drag project) car:
Custom 30 turn 180 motor, 3.83:1 gear, four cells: 30kph (18.6 mph)
Custom 30 turn 180 motor, 3.83:1 gear, six cells: 38kph (23.6 mph)
Old 01-01-2004, 10:57 AM
nrsjs's Avatar
I can't take any pics of the results from my mini-z since it doens't work anymore and those results are just from a while ago, but I'll run the same tests again on my xmod today and take pics for you. Might not be till later though, cause I have to watch the Gator bowl (go Mountaineers!!)
Also, about my xmod jumping off the tester with AWD, it might be because of my twitchy steering. The steering tends to jump back and forth and this causes it to just go flying off of the thing.
Old 01-01-2004, 11:31 AM
nrsjs's Avatar
Ok, managed to push it to 38kmh with 100% fresh cells. 24 mph but the batteries were run down a bit so I couldn't get the 100m time down and I don't feel like recharging again, but it's still pretty low.
(Sorry for the low quality pics )
This one's for the top speed... it was balancing at 37 for a while, the it started bouncing back and forth between 37 and 38, then it just held at 38... then my tire slipped off the rim and toward the middle of the car and half the tire was ground off on my plastic skidplate... but I got the 38 kph shot taken.
Old 01-01-2004, 11:33 AM
nrsjs's Avatar
And here's the 100m time...
Old 01-01-2004, 11:40 AM
nrsjs's Avatar
And here's the xmod on and off the tester, showing how i removed the front spinner thing if you were wondering what I was talking about
Also, that big thing on the front of the car is the battery pack for the 5th and 6th cells. I removed the hood and run the wires through that space. Next best thing to a big blower coming out of the hood It's such a pain to fit it in the body that I just let it sit on the hood when I am testing it.
Also, that black stuff around the rear part of the tester is little pieces of tire that were ground off when my wheel came off.
Old 01-01-2004, 12:29 PM
ax0n
you know though, once under load and with wind drag, those cars won't see anywhere near those times or top speeds, right?
The best way to get a good realistic reading is to use an apparatus like a lap timer, with light beams you have to break.
Just like a real car... using a dyno is great, but it isn't going to really tell you how fast your car is going to be once you take it to the track. Weight, gearing, traction, stability, and drag all play major roles in your actual track times and top speed.
Old 01-01-2004, 12:37 PM
nrsjs's Avatar
It's been discussed over and over and over and over and over...
The tests with this dyno are just for comparison, hence the name of the topic?
And also, I know that a mini-z would make a xmod look like a piece of crap on an actual course, handling and quickness taken into play. This is just a top speed thing.
It can also be mentioned that my mini-z was a mr1 rx-7 chassis, not one of the F1's or enzo's
Old 01-01-2004, 01:36 PM
my graphing calculator has a conversion program. if i find out how many feet it do per second, i can see how many mph its going. myabe one day i'll try it
Old 01-01-2004, 01:41 PM
nrsjs's Avatar
well it's the simple formula velocity = displacement / time. You have to convert a few things to get it to mph but it's basically no prob if you've ever taken a physics class. Problem is, I just don't have anywhere big enough to get an accurate measurement at top speed. I'm going back to school in a week and I should find somewhere good up there and I'll post it here.
Old 01-01-2004, 02:54 PM
newbitowner's Avatar
newbitowner newbitowner is offline
That mini dyno is amazing! Where can I get one?
Does stronger magnets=reduced top speed? RC 2NR XMODS 6 02-20-2005 11:05 AM
Racing Top Speed Motor 2fast4u XMODS Parts and Hop-Ups 2 01-26-2004 08:36 PM
The Tamiya Mini speed checker said 39kph(24mph). newbitowner XMODS 16 01-20-2004 06:52 PM
Mental Idea Accelaration And Top Speed! scottyboyfun Bit Char-G / MicroSizers 17 01-07-2003 01:54 PM
