Old 12-30-2003, 11:48 PM
mattjar mattjar is offline
Unhappy someone please help me out
i have the civic x-mods and i really want to know if a mini-z body will fit onit and if so what size i need please someone help me out
Old 12-31-2003, 08:27 PM
xmodsman's Avatar
xmodsman xmodsman is offline
Send a message via AIM to xmodsman
I hate it when no one helps out so I am here to help!
They don't fit.lol
blue RSX
wild silver body kit
stage 2 drift motor
5th cell mod
soft springs front
hard back
3.5 steering
custom plastic skidplate
white rims
metal lugnuts
mini-z tires
and custom painted chasis
Old 12-31-2003, 09:00 PM
lemans23's Avatar
lemans23 lemans23 is offline
GT3 Drift Master
They don't fit.lol
actually, with modification, the bodies CAN fit. so don't discourage the dude.
Bit Char-G= FRIED WITH 4.0 MOTOR
RSX XMOD:
Stage 2 yellow motor
.5 cm
Hard slick rear
hard tread front
5 cells
ALL ALKALINE
Old 12-31-2003, 09:26 PM
OverBoostSupra OverBoostSupra is offline
Can we help the poor man on how to make it fit? I personally dont know but if you do know please tell him so he can do what he wants.
-Supra Chassis
-Stage 2 motor ( drag )
-Hard tires at rear soft up front
-stage 2 suspension ( soft up front and stiff rear )
-Wheel kit ("snow flakes")
- Tie rod
-Revell 240z model body ( custom mounted and painted blue with white hood )
-Light kit
-Custom graphics
- The most deadly soldier is the soldier without the instruction manual for his gun.-
Old 12-31-2003, 11:31 PM
KnotHole's Avatar
KnotHole KnotHole is offline
JesUSAves
Mini-z Body on X-mod
From what Ive heard others (ie...BC) saying is that your going to have to mod the mounting brackets. Keep asking around and im sure someone has done one and can help you out. Good luck !
Old 01-01-2004, 02:05 AM
neurokinetik's Avatar
Mad Scientist
The real answer: It depends on what body you want to use, and how much work you are willing to put into it. I made the C5R body fit, though it was quite difficult and required some hacks to the chassis to make it work. I also did a MINI Cooper, which aside from alot of sanding in the wheelwells, went pretty easily.
Also keep in mind that since you have a Civic, you have the longest chassis. Look for a Mini-Z body that matches that setting, otherwise you'll have to buy a new driveshaft. (Though slugbugg's CF driveshafts are nice enough to buy even if you aren't primarily looking to get a different size)
You'll normally have to modify or make a new front mounting tab, and for the rear, you can either use velcro on the battery clips or else fab a standoff to screw the stock rear clip into.
