12-30-2003, 04:03 PM
problem with testors paint
I wanted to paint my supra black and green, so, i sanded it all down, sprayed 2 coats of primer, and then i covered the parts of the body i didnt want painted, with masking tape, so then after primers dried, i spray on a coat of flourescent green. Well, it dried a while ago, but i want to know why the heck the paint is all rubbery? i mean the paint on the newspaper i painted over, is rubbery and stretchy..
its like that on the body too
got any suggestions?
12-30-2003, 04:38 PM
ok i think i know the main reason this turned out crappy, is beacuse i used testors grey primer, ill try using another brand of primer, whats the best primer to use, and what color, to keep a flourescent green, at a flourescent color? i used gray last time, and the green came out army green, is there also any way to make the green look shiny?
ANY help would be appreciated. thanks.
EDIT:
Whats should i use to strip off this crap paint job? (and strip it off fast, besides sanding.)
12-30-2003, 05:43 PM
you didnt let it dry long enough... it may feel hard to the tip of your finger but it wasnt fully dried. and one coat is not enough.
