Old 12-30-2003, 03:34 PM
RSXRacer001 RSXRacer001 is offline
Put Custom User Text Here
Send a message via AIM to RSXRacer001
Is this normal?
I was outside today playing with my xmod and when i turned, one back wheel would come off. I have an Acura RSX, bearing upgarde, drag motor, soft springs in front, hard in back, and Ic3 batteries. Is that normal to happen?
Old 12-30-2003, 03:37 PM
Bad Company's Avatar
No it is not normal. I would make sure that your wheel nut is on tight, and is not stripped.
Old 12-30-2003, 03:39 PM
when i said wheel, i meant tire.
sorry for the confusion.
Old 12-30-2003, 03:41 PM
Oh, well that iss actually quite normal for my 6 cell car. It is constantly throwing the rear tire off. You could glue it on, or stick a piece of thin double sided tape between the tire and wheel.
Old 12-30-2003, 03:44 PM
but this is only a 4cell
Old 12-30-2003, 03:51 PM
So, you can still secure the wheels the same way. The only thing holding the tires on is a little rib.
Old 12-31-2003, 11:17 PM
KnotHole's Avatar
KnotHole KnotHole is offline
JesUSAves
Thumbs up
Use the double sided tape. You can get the thin kind from any office supply store. Your tires will still come off (when you pull them) and most of the time the thin tape wont leave any sticky stuff on your tires or wheels...Its just something that I use. I hope it works for you.
PS...Or just super glue them on !!!...
Old 01-01-2004, 12:50 AM
xodus xodus is offline
XmodSource Dot Com
yes
yes its normal..same thing here..when i use any stage 2 motors..it does it..i think it happens most w/ soft tires and blue s2..
Old 01-01-2004, 02:48 PM
thanks for the info... i will use it.
Old 01-01-2004, 04:24 PM
XmodSource Dot Com
my opinon
my bad..i actully think the white (drift) is the best one out of the s2 upgrade pack..just thought i'd let u kno..im also trying to see what tire combo would work best..(if anyone knows..let me know)
Old 01-01-2004, 05:00 PM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
use rubber cement to glue it to the rim. if you want them to permemantaly put them on the rim use super glue. but if you want to change them use rubber cement. it will come off and doesnt ruin anything
NEVER UNDERESTIMATE THE POWER
Turret Insides and Motor Behavior - Is this normal? Bistromatic Combat Digi Q 0 10-17-2003 04:09 PM
Sold Pro Microsizer Bought A Normal One 2G2SILVERSTRAT Bit Char-G / MicroSizers 5 07-04-2003 10:31 PM
Is this normal? bjv5 Epoch RC1/43 3 04-05-2003 01:42 PM
Special editon gearing vrs normal gearing Smurf Bit Char-G Parts and Hop-Ups 2 10-09-2002 11:08 AM
Steering spring messed up wont return to normal SPEED Bit Char-G / MicroSizers 0 08-21-2002 05:36 PM
