My antenna got hooked on my cashmere sweater (cant have that happen) so I had to bend the antenna out of shape as to not ruin my sweter (which could pay for about 5 Xmods ) Was there anyway I could replace it, like does anyone have an extra one, or could I make one out of a wire from a coat hanger, thanks.
I'm assuming you mean the car's antennea and not the transmitter's. BEst thing to do is to go to the hobby shop and buy an antennea wire and straw, then unsolder the old antennea and solder the wire onto the little bar that the screw feeds through to hold the antennea down. Then feed the wire through the straw and let about an inch hang out the top. Clip it and feed the straw and wire through the hole in the bodya nd reattach the body. Presto, solution.
This is your brain.....
i made my own anntena out of some thin copper strands twisted together in about a 3 and a half inch strand then i coiled it so it would fit under my L88 corrvette body. no drop in range at all
racing on pavement is for wussies.
