I picked up my XMODS white supra today! I am realy pleased with its performance but i have one problem. Every time i turn to the left at anything more than a quarter throttle the diff unloads to the left and makes it understeer real bad. some times on slick surfaces i have to stop to get the diff to turn both tires. is there anything i can do besides glueing the diff together to stop this?
racing on pavement is for wussies.
Any gunk on your tires? Mine will do this when they accumulate too much dust (and cat hair) from driving around on the floor. You might also try buying the tire upgrade set to see which tires work best for your driving surface.
Inside, the stock slicks work great on my hardwood floors, but in the garage I found that the hard treads work much better.
You might also look into the upgrade suspension kit; stiffer springs will keep all tires planted better.
Don't glue your diff!!!! This will cause nasty spin-outs all the time when cornering.
thanks i have some stuff on my tires thats probly it. it started when i ran it in our shop that has smooth concrete floor with dust and god knows what else on it. im starting my first custom job on my xmod today im putting a 67 corvette L88 model body on! it fits so perfect its like the body is meant to be there the rx crystal sits right in front of the cowl and sticks up a bit but is perfectly hidden by the hood scoop
