Old 12-28-2003, 04:48 PM
10_second_supra 10_second_supra is offline
xmod destroyer
X mod help thread
If you have any questions or need help with you r xmod post them here. I made this thread because i think it is geting a little anoying seein some many post about help for the same thing.
Bad company- By the way could you make this a sticky
350z-SS 130 motor, bearings cf driveshaft, custom paint,
supra- high torque 180, 6 cell bearings,
civic- powerdash, bearings,cf driveshaft
rsx-fried
4supras fried
2 skylines detroyed
1 civic destroyee
Old 12-28-2003, 04:57 PM
nrsjs's Avatar
nrsjs nrsjs is offline
What's the difference between the 3 different tie rods that come with that steering upgrade? My wheels jump back and forth a bit when going in a straight line (possibly because of the front right axle that came with my 4wd kit, it's a little crooked) which makes it sorta tricky to ride in a straight line, would anythign in that kit help?
Old 12-28-2003, 05:10 PM
xmod destroyer
The reason you xmod steering may jump back and forth is because of the sterring play. When your car is assembled look at the front nuckle with the tie rod in it. It has plenty of room to move back and forth and side to side. You can fix this by using about an half an inch of tephlone tape. Then wrap a 1 and a half inch piece around each end of your tie rod. This should fix your wobling. And give the tape a little while to break in.
The 4.5 is good for sharp turns.
The 4 is good for wider turns.
The 3 is good for straight stretches.
And the suspension will also help your car because you can use diffrent hardnesses and softnesses to make your car perform better on certian surfaces.
rsx-fried
4supras fried
2 skylines detroyed
1 civic destroyee
Old 12-28-2003, 05:47 PM
nrsjs's Avatar
Thanks
AWD with Resistor Mod for steering cool_cars XMODS Mods and Projects 20 12-04-2004 03:10 AM
Best Mod Contest (UNOFFICIAL) midget_man1387 Bit Char-G Mods and Projects 56 03-17-2003 10:38 PM
