Old 10-07-2002, 10:22 AM
e_lm_70 e_lm_70 is offline
Question Booster Controller range increase
Hi,
With my clone BitCharg-G (27MHz) Increasing the power of the 3V surce (1.5Vx2 batteries), up to 5V with a fix power supplier, increase of about 100% the operating range. The OEM has a telescopic antenna.
With my Tommy Booster Controller, even increasing the source power (I have replaced one of the two 1.5V batterie, with a 2.6V batterie) no advantage at all is visible !
With the booster controller, the range is just 2 meters for run the car normaly (but till the boster car) , and 1 meter more if turbo is active.
It look that the turbo signal is far stronger then the normal mode !
The renge is so poor, that I dubt, that with changing the antenna I will get an acceptable range.
Why the power increase doesn#T work with the tomy controller ?
What else could be done !
Danke
Old 10-11-2002, 08:53 PM
tinyrc's Avatar
tinyrc tinyrc is offline
Very interesting! Do you have a TOMY non-booster controller to compare it to? Maybe the TOMY booster has some kind of limiter that the clone does not?
Old 10-14-2002, 10:35 AM
Yes,
My Tomy G05 (57MHz) after killed the capacitor in the TX has a huge range (more then 6m) with my standard NiMh in the TX (I don't use alkaline)
My Tomy G02 (45MHz) has no TX capacitor, I killed the capacitor in the car, the range has increase from 2m to 2.5m.
The G05 has already a nice range without roll out the antenna.
The OEM Bit has a good range (6m + ) with overpower, with standard bat I got just 3m !
controller mod & solution for poor range natedogg4674 ZipZaps 4 10-13-2002 09:40 PM
Sucky Booster Controller aballen Bit Char-G Mods and Projects 3 09-28-2002 05:19 PM
Booster machine range increase... dumboi07 Bit Char-G / MicroSizers 0 08-26-2002 11:53 PM
Booster Controller Range Enhanced!! Alex Bit Char-G Mods and Projects 6 08-18-2002 04:44 PM
just got my 4 ch. controller and booster ZeroHero Bit Char-G / MicroSizers 8 07-07-2002 03:19 PM
