Old 12-27-2003, 11:17 PM
rs2000's Avatar
rs2000 rs2000 is offline
Xmodder
Send a message via AIM to rs2000 Send a message via Yahoo to rs2000
Unhappy Overheating!
IT GETS HOT!
My heatsink and motor get hot enough to fry an egg now that i got a stage 2 motor (yellow) and some rayovac rechargables! After about 5 mins of run time i have to quit because im afraid of screwin it up. Will the motor burn up if i dont let it cool or is there a way to keep it cool while im using it?
*Nissan 350z*
[COLOR=royal blue]
-Stage 2 red SB hybrid motor (soon to be neo mags, BB can and BB endbell)
-IC-3 800 mAH bats - 4 cell
-AWD
-Blue springs up front, silver in back
-Aluminum locknuts at all four corners
-Locked rear diff for drift action!
[/color]
Old 12-28-2003, 12:01 AM
rs2000's Avatar
Xmodder
anyone?
Old 12-28-2003, 01:15 AM
Daazndood Daazndood is offline
i have a stage 2 red with out a heat sink and it gets hot in about 3 or 4 minutes. and i mean hot!!! i usually dont run for more than 5 minutes just to be safe.
Old 12-28-2003, 01:46 AM
rs2000's Avatar
Xmodder
Is there any type of fan that would fit in these? I found a mini intercooler on ebay but they wanted 16 bucks! I might try to sqeeze the fan (the small one) from my CPU in there.
Old 12-28-2003, 07:35 AM
Bad Company's Avatar
No need to type so large. I run a stage 2 without a heat sink and on 6 cells for 10-15 minutes, and it get hot, but still runs fine. Yoiu should be ok running it longer with a stock setup.
Old 12-28-2003, 09:09 AM
pacificwarriors's Avatar
pacificwarriors pacificwarriors is offline
MY ENZO!!!!!!
At radio shack i saw a mini fan i guess you could put it in your xmod and it would cool it off, it looked just like a fan in a real car.
