Old 12-27-2003, 08:02 PM
rpm
how to light up your xmods interior without buying a kit
To make the interior of your xmods glow, you will need 1 christmas light bulb (preferrably white)and 2 pairs of 5 inches of
audio wire. Here are the steps:
1.Remove the cap from the bottom of the light
2.Gently take one of the light wires and connect it to a piece of audio wire.
3.Do the same with the other light wire.
4.Inside of the xmods, there is a white plug.
5.There are four prongs in the white plug.
6.Make sure the front of your car is facing left.
7.Roll up the naked wire that is from the light bulb
8.Do the same to the other.
9.Then gently push one rolled wire into the plug at the last prong that is against the wall of the white plug.
10.Push the other wire into the 3rd to last prong, but on the opposite side.
11.Tape down the wires with electrical tape and make sure that they are in place and working before taping. You can check by turning on your xmod. The lights should turn on.
12.Gently and slowly put you case back on (WHILE THE CAR IS ON) and then your done. The lights should stay on giving your car a glow from the inside and will reflect on the bottom. Best with a red supra.
Old 12-27-2003, 09:27 PM
dEmOnRaCeR's Avatar
dEmOnRaCeR dEmOnRaCeR is offline
"Its OK I had subway"
Do u have any pics
Old 12-27-2003, 09:44 PM
rpm
you will see pics in a couple of days. the work is worth it
CJ's Xmods FAQ (Updated June 27th.) cj1267 XMODS 64 05-30-2007 08:43 PM
xmods drift kit review jaubery XMODS 1 09-13-2004 04:25 PM
In need of an All Wheel Drive kit, Command Logic Light Kit, Ball Bearings, etc.? RC 2NR XMODS Parts and Hop-Ups 4 02-25-2004 07:54 PM
WTB: XMods -> AWD, Light Kit, Metal Bearings, Suspension Kit RC 2NR For Sale/Trade 0 02-01-2004 09:51 AM
Xmods Announcement cj1267 XMODS 2 10-16-2003 05:34 PM
