Old 12-27-2003, 12:21 AM
Daazndood Daazndood is offline
gold rims and nuts on a white supra
well, heres a picture of my exterior stock white supra exept for the rims.
Old 12-27-2003, 08:55 AM
Bad Company's Avatar
Looks good! Maybe paint the silver under the headlight lenses gold too and stick a gold pinstripe down the side.
Old 12-29-2003, 01:28 AM
35thSLP 35thSLP is offline
Thumbs up Would look awsome with some decals from decals-r-us
Looks great! Would look totally custom with the gold metallic decals from decals-r-us . They sell a kit for the supra (there is a photo of it on the header of the site) in Gold metallic that would look awsome on your car.
Old 01-01-2004, 12:41 AM
eLeMeNt_sK8er04's Avatar
eLeMeNt_sK8er04 eLeMeNt_sK8er04 is offline
i think ill die early ..
Send a message via Yahoo to eLeMeNt_sK8er04
I apinted my rims white (on my white supra) it seems a little bit stoopid.....i know i know..... plese save the hysterical lafing and evil pointing until the end of the post.....but to tell you the truth the white rims look cool
Old 01-01-2004, 08:58 PM
Joey's Avatar
Joey Joey is offline
You could try painting the sideskirts, bumpers, and nuts a different color - that'd tie the car together without it all being one solid color. Maybe some matching vinyl, or making that a third color by itself.
White on white doesn't sound too bad though.
Mazda Savanna RX-7
stage 2 motor | spaced wheels
Old 01-06-2004, 08:48 PM
food123 food123 is offline
That's sweet man! I like nice, clean, understated cars. What do you have under the "hood"?
Old 01-06-2004, 08:54 PM
Racer240's Avatar
Racer240 Racer240 is offline
You too? Here's my beater car:
Umm... is it alright if I post my specs here?
Specs: AWD|Soft Springs Front|Hard Springs Rear|3° Tie-Rod|Soft Tread Tires Front|Stock Tires Rear|S2 Blue Motor|Battery Compartments Foward|5 Cells
Custom: Hand Painted White Wheels|Hand Painted Metallic Silver Exhaust|Decals|Green Plastic Skid Plate|Quick Connect/Disconnect 5th Cell Plug
Old 01-07-2004, 05:48 PM
I'm sorta new. What are the benifits of mixing and matching tires and springs (like you did) And what's a tie rod?
Old 01-07-2004, 09:00 PM
Joey's Avatar
Handling characteristics - softer tires yield more grip, as I'm sure you knew, but it's easier to drive a certain way (say, drifting, or going through lots of sequential turns) if you car is set up to behave specifically the way you want. Even if that means that the rear should act differently than the front.
Mazda Savanna RX-7
Old 01-08-2004, 03:20 PM
so if you want oversteer then you'd want hard back tires?
Old 01-08-2004, 03:51 PM
purfishy's Avatar
purfishy purfishy is offline
BACK BEEEEEEEEEEECH!!
Send a message via AIM to purfishy
yes
for shizzle
Old 01-08-2004, 04:29 PM
OverBoostSupra OverBoostSupra is offline
I put hardies in the back of my brothers skyline ( ginny pig car! ) it was uncontrolable. But it was fun drifint around. If your looking for nice tight controlled turns i dont recomend hard tires
-Supra Chassis
-Stage 2 motor ( drag )
-Hard tires at rear soft up front
-stage 2 suspension ( soft up front and stiff rear )
-Wheel kit ("snow flakes")
- Tie rod
-Revell 240z model body ( custom mounted and painted blue with white hood )
-Light kit
-Custom graphics
- The most deadly soldier is the soldier without the instruction manual for his gun.-
Old 01-08-2004, 07:18 PM
ok cool, but how does mixing springs help?
Old 01-08-2004, 08:05 PM
Joey's Avatar
If you mean having a different stiffness on each end, it's the same meticulous tuning principle as the tires. If you're talking about the actual cutting and rebonding of different types of springs, it's so that you can adjust how they bound and rebound more directly. If you put (half) a set of soft springs on top of (half) a set of stiff ones, then the car will roll relatively easily in a turn to begin with, but once the soft springs' travel has reached its limit, the stiff springs will 'kick in' so to speak, and the body will hardly roll at all.
It's all about furthering the level of customization.
Mazda Savanna RX-7
Old 01-09-2004, 03:08 PM
ok thanks
