Old 12-25-2003, 07:59 PM
joe_t1g joe_t1g is offline
s2 / SB hybrid
I was thinking of using a stage2 11t motor, decreasing the winds a lil, increasing the timing and switching out the magnets for SpinBrush magnets... please let me know your thoughts.
I wanted to use the stage2 11t for speed and SB magnets for the torque.
I don't feel like putting money down for a NML or Redline yet until the rest of the guys I race against up the ante.
In conjunction with the hybrid motor I wanted to do a 6 cell upgrade.
ANY thoughts based on REAL experience, thanks
Old 12-26-2003, 12:19 AM
neurokinetik's Avatar
Mad Scientist
It works, but I don't think the combo has quite enough torque to push the tall gears. Go with a 9 or 10 tooth.
I still say the 180 motor is the way to go for a cost-effective upgrade. Just $10-13, and the 11 tooth gear is like a drift gear with this motor. Again, it won't fit in the RSX.
Old 12-26-2003, 12:39 AM
SKYHIGH SKYHIGH is offline
why wont it fit in the rsx?
Old 12-26-2003, 01:22 AM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
rsx uses a shorter wheelbase (middle setting) and won't have the room for the 180 motor and in case you ask, 180 motors are longer by over 1 cm
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 12-26-2003, 02:15 AM
ok thats cool thanx but on my rsx i have converted it to fwd, so could I use the longer driveshaft, cut off the cone, and be able to use it
Old 12-26-2003, 08:31 AM
Bad Company's Avatar
You would still have to keep the same wheelbase for your body to fit, and to do that, you would have to leave the rear chassis in the middle position. That is what the motor mounts to, so you still would not have the room.
Old 12-26-2003, 09:10 AM
RC 2NR RC 2NR is offline
TinyRC XModder
What is this motor called, an can you get it a RS?
Old 12-27-2003, 10:44 AM
red02zx3 red02zx3 is offline
I believe its the tamtech 180 motor that everyone is using. I found one on ebay for 10 bucks. Its a black motor...youll just have to swap the pinions.
Old 12-27-2003, 02:26 PM
I Shall Return!
my motor
hey my 180 motor ( or so i beleive it to be a 180 because its bigger than stock but itll fit..) my motor is a "Hoppin Hydros" "Big Bad Johnson Motor" it cost me like 5.95 at my lhs, i also picked up a 12Tpinion to take advantage of its torque. another plus is that the motor was built for 2.4V applications however out x-mods are 4.8 and sometimes even 7.2 so i beleive it will fly.. im just not sure if it will burn out my esc (i dont wanna ruin my xmod i love it to death... my mom hates me because i rearranged our living room into a race coarse lol) so please could someone tell my if this motor will work??
Old 12-27-2003, 02:29 PM
from what I understand, the 180s will work without hurting the XMODs. Since its made for 2.4V , Id say youll be Ok, cause its not built to draw major amounts of current......anyone?
Old 12-27-2003, 03:06 PM
I Shall Return!
alright thnx...ill give it a shot once i finish painting
SB Hybrid Motor Question Rodrick XMODS Parts and Hop-Ups 13 10-24-2005 07:25 PM
cooler SB hybrid motor ViperKid XMODS Mods and Projects 12 02-03-2004 06:36 PM
SB hybrid.. 93Supra0wner XMODS Mods and Projects 0 01-15-2004 09:58 PM
My latest hybrid motor godsmistake XMODS Mods and Projects 2 12-11-2003 04:55 PM
