Old 12-25-2003, 12:13 PM
danny_v_l's Avatar
danny_v_l danny_v_l is offline
Umm.. Teal Rsx
Lenghts
Hey Guys i'm gonna get my second x-mod, and i have seen this around but what are the lengths of the cars like some use the largest seting some use middem some use the short i need one that will fit a 10 size motor and a two cell mod, do u think the supra will fit it?
Whats left to say when theres nothing left to say
|Skyline Gallery|Civic Gallery|RSX Gallery|Supra Gallery|My Supra|My RSX|
Old 12-25-2003, 12:19 PM
Bad Company's Avatar
All of the cars use the long setting except the RSX, it uses the middle setting.
Old 12-25-2003, 01:52 PM
maxximum attack
BC,
Can you change the wheelbase to the medium setting without changing the driveshaft? I wanto do this mod, But i have the long chassis setting and this fellow has the middle setting. Do I need a new driveshaft or can I just go ahead and shorten the wheelbase by swapping screw slots?
thanx
Old 12-25-2003, 02:00 PM
maxximum attack
here is the undershot.
Old 12-25-2003, 02:31 PM
You can use the long shaft and change to the middle setting only if you are using the 2WD Rear Drive setup. What you have to do is cut down the front axle retainer? The piece that goes between the wheel axle pins and hold them in place. That piece also keeps the shaft from sliding foreward in the 2WD setup.
You will have to remove the same amount you move the shaft foreward, which would be the distance from the center of the longest screw hole to the center of the center screw hole.
Keep in mind, if you do this, you will not be able to go back the long setting and use that front axle retainer on 2WD, but you can go back to AWD.
Old 12-25-2003, 03:32 PM
maxximum attack
So if I wat to have 4WD, I would have to get a new medium sized drive-shaft?
I've seen the driveshafts in CJ's FAQ but can you get them OTC from radioshack.
My, dad I in the states and I can get him to pick up one for me.
Old 12-25-2003, 03:37 PM
If you want to change the setting AND have AWD, you will have to buy the correct shaft.
Old 12-25-2003, 03:49 PM
maxximum attack
Thanx guy.
Can I get the shafts from RS? If not, How can I get them?
Old 12-25-2003, 04:10 PM
You should be able to order them thru the 800 number or thru a store. Look up the part number in CJ's FAQ.
Old 12-25-2003, 09:28 PM
danny_v_l's Avatar
Umm.. Teal Rsx
so bc u think i can fit a two aaa cell holder in the car and a 180 motor?, i ask u this because didn't u do a two cell to a supra?
Old 12-25-2003, 09:31 PM
If the 180 motor is any bigger than the Xmod motors, you will not be able to without shimming the rear end up on the body.
